How should I use the Jacobi equation to determine the nature of this?
  • Thread starter Thread starter Math100
    Calculus
Math100
Let ## n>1 ## be a positive integer such that the functional ## S[y]=\int_{0}^{1}(y')^{n}e^{y}dx, y(0)=1, y(1)=A>1 ##, has a stationary path given by ## y=n\ln(cx+e^{1/n}) ##, where ## c=e^{A/n}-e^{1/n} ##. Use the Jacobi equation to determine the nature of this stationary path.
Jacobi equation: ## \frac{d}{dx}(P(x)\frac{du}{dx})-Q(x)u=0, u(a)=0, u'(a)=1 ##, where ## P(x)=\frac{\partial^2 F}{\partial y'^2} ## and ## Q(x)=\frac{\partial^2 F}{\partial y^2}-\frac{d}{dx}(\frac{\partial^2 F}{\partial y\partial y'}) ## vanishes at ## x=\tilde{a} ##.
For sufficiently small ## b-a ##, we have
a) if ## P(x)=\frac{\partial^2 F}{\partial y'^2}>0, a\leq x\leq b, S[y] ## has a minimum;
b) if ## P(x)=\frac{\partial^2 F}{\partial y'^2}<0, a\leq x\leq b, S[y] ## has a maximum.
Jacobi's necessary condition: If the stationary path ## y(x) ## corresponds to a minimum of the functional ## S[y]=\int_{a}^{b}F(x, y, y')dx, y(a)=A, y(b)=B ##, and if ## P(x)=\frac{\partial^2 F}{\partial y'^2}>0 ## along the path, then the open interval ## a<x<b ## does not contain points conjugate to ## a ##.
A sufficient condition: If ## y(x) ## is an admissible function for the functional ## S[y]=\int_{a}^{b}F(x, y, y')dx, y(a)=A, y(b)=B ## and satisfies the three conditions listed below, then the functional has a weak local minimum along ## y(x) ##.
a) The function ## y(x) ## satisfies the Euler-Lagrange equation, ## \frac{d}{dx}(\frac{\partial F}{\partial y'})-\frac{\partial F}{\partial y}=0 ##.
b) Along the curve ## y(x), P(x)=\frac{\partial^2 F}{\partial y'^2}>0 ## for ## a\leq x\leq b ##.
c) The closed interval ## [a, b] ## contains no points conjugate to the point ## x=a ##.
Here's my work:
Let ## n>1 ## be a positive integer.
Consider the functional ## S[y]=\int_{0}^{1}(y')^{n}e^{y}dx, y(0)=1, y(1)=A>1 ##.
By definition, the Jacobi equation is ## \frac{d}{dx}(P(x)\frac{du}{dx})-Q(x)u=0, u(a)=0, u'(a)=1 ##, where ## P(x)=\frac{\partial^2 F}{\partial y'^2} ## and ## Q(x)=\frac{\partial^2 F}{\partial y^2}-\frac{d}{dx}(\frac{\partial^2 F}{\partial y\partial y'}) ## vanishes at ## x=\tilde{a} ##.
Note that ## F(x, y, y')=(y')^{n}e^{y} ##.
This gives ## P(x)=\frac{\partial^2 F}{\partial y'^2}=n(n-1)(y')^{n-2}e^{y} ## and ## Q(x)=\frac{\partial^2 F}{\partial y^2}-\frac{d}{dx}(\frac{\partial^2 F}{\partial y\partial y'})=(y')^{n}e^{y} ##.
Observe that ## \frac{d}{dx}(P(x)\frac{du}{dx})-Q(x)u=0\implies \frac{d}{dx}((n(n-1)(y')^{n-2}e^{y})\frac{du}{dx})-(y')^{n}e^{y}\cdot u=0\implies n(n-1)(y')^{n-2}e^{y}\frac{d^2u}{dx^2}-(y')^{n}e^{y}\cdot u=0 ##.
Thus, the Jacobi equation is ## n(n-1)\frac{d^2u}{dx^2}-(y')^2\cdot u=0 ##.
From this Jacobi equation above, how can we determine the nature of this stationary path?
You are given the solution of the EL equation as y(x) = n \ln(cx + e^{1/n}) so that y&#039; = (cn)/(cx + e^{1/n}) and e^y = (cx + e^{1/n})^n where c = e^{A/n} - e^{1/n} &gt; 0. Hence \begin{split}<br /> Q &amp;= (y&#039;)^ne^y - \frac{d}{dx}(n(y&#039;)^{n-1}e^y) \\<br /> &amp;= \left(\frac{cn}{cx + e^{1/n}}\right)^n(cx + e^{1/n})^n <br /> - \frac{d}{dx}\left( n \left( \frac{cn}{cx + e^{1/x}}\right)^{n-1}(cx + e^{1/n})^n\right) \\<br /> &amp;= (cn)^n - \frac{d}{dx}\left( n(cn)^{n-1}(cx + e^{1/n})\right) \\<br /> &amp;= 0 \end{split} and I leave you to determine P.
pasmith said:
You are given the solution of the EL equation as y(x) = n \ln(cx + e^{1/n}) so that y&#039; = (cn)/(cx + e^{1/n}) and e^y = (cx + e^{1/n})^n where c = e^{A/n} - e^{1/n} &gt; 0. Hence \begin{split}<br /> Q &amp;= (y&#039;)^ne^y - \frac{d}{dx}(n(y&#039;)^{n-1}e^y) \\<br /> &amp;= \left(\frac{cn}{cx + e^{1/n}}\right)^n(cx + e^{1/n})^n<br /> - \frac{d}{dx}\left( n \left( \frac{cn}{cx + e^{1/x}}\right)^{n-1}(cx + e^{1/n})^n\right) \\<br /> &amp;= (cn)^n - \frac{d}{dx}\left( n(cn)^{n-1}(cx + e^{1/n})\right) \\<br /> &amp;= 0 \end{split} and I leave you to determine P.
Based on ## F(x, y, y')=(y')^{n}e^{y} ##, I've got ## P(x)=\frac{\partial^2 F}{\partial y'^2}=n(n-1)(y')^{n-2}e^{y}=n(n-1)(\frac{cn}{cx+e^{1/n}})^{n-2}\cdot (cx+e^{1/n})^{n}=n(n-1)(cn)^{n-2}\cdot (cx+e^{1/n})^{2} ##. After substituting ## c=e^{A/n}-e^{1/n} ##, I've got ## P(x)=n(n-1)[(e^{A/n}-e^{1/n})n]^{n-2}\cdot [(e^{A/n}-e^{1/n})x+e^{1/n}]^2 ##. But how should I simplify ## P(x) ## from here?
Do not substitute for c; it is enough to note that c &gt; 0 and n &gt; 1. P(x) is a quadratic in x. What is the sign of its leading coefficient, and where are its zeros? Is it positive or negative on (0,1)?
Since Q = 0 the Jacobi equation reduces to <br /> P(x)u&#039;(x) = P(0)u&#039;(0).
So ## P(x)=n(n-1)(cn)^{n-2}\cdot (cx+e^{1/n})^2\implies P(0)=n(n-1)(cn)^{n-2}\cdot e^{2/n} ##. But how should I find out if ## P(x)<0 ## or if ## P(x)>0 ##? And for the interval ## (0, 1) ##, what's ## 1 ## in here in knowing that ## x=0 ##?
The sign of its leading coefficient is positive and ## P(x) ## has one zero at ## x=-\frac{e^{1/n}}{c} ##. Also, on the conditions that ## c>0, n>1 ##, I found out that ## P(x)=n(n-1)(cn)^{n-2}\cdot (cx+e^{1/n})^2>0 ## for ## 0\leq x\leq 1 ##. Does this indicate that our functional ## S[y] ## has a minimum (In other words, this is the nature of our stationary path)?
