MHB How should this matrix be multiplied
  • Thread starter Thread starter mathlearn
    Matrix
The discussion focuses on the multiplication of two matrices, A and B, where A is a 1x2 matrix and B is a 2x1 matrix. The resulting matrix AB is a 1x1 matrix, calculated by taking the inner product of A's row and B's column. The calculation shows that c_{11} equals 7, leading to the result AB being a 1x1 matrix with the value of 7. Additionally, the process for determining which rows and columns to multiply is clarified, emphasizing that each row of A is multiplied with each column of B to form the resulting matrix.
mathlearn
$A=\begin{bmatrix}
3&2\\
\end{bmatrix} B=\begin{bmatrix}
1\\
2\end{bmatrix}$
Find the value of the matrix $AB$.
The order of the first matrix is 1*2
The order of the second matrix is 2*1
Matrix AB should be 1*1
I am a bit struggling in determining the way that these two matrices should be multiplied
Many thanks :)
Mathematics news on Phys.org
You are correct about the order of the matrices! (Yes)
We have the following:
$$AB=\begin{bmatrix}
3&2\\
\end{bmatrix} \begin{bmatrix}
1\\
2\end{bmatrix}=\begin{bmatrix}
c_{11}
\end{bmatrix}$$
To calculate the element $c_{11}$ we have to multiply the $1$st row of $A$ with the $1$st column of $B$, as an inner product. So we get the following:
$$c_{11}=3\cdot 1+2\cdot 2=3+4=7$$ So, the result is $$AB=\begin{bmatrix}
\end{bmatrix}$$
3&2\\
1\\
c_{11}
\end{bmatrix}$$
\end{bmatrix}$$
Thanks :) I can see it in this problem now
But how do we know which row are to be multiplied with what column ?
Let $A=\begin{pmatrix}
1 & 2 & 3 \\
4 & 5 & 6 \\
7 & 8 & 9
\end{pmatrix}$ and $B=\begin{pmatrix}
1 & 2 \\
3 & 4 \\
5 & 6
\end{pmatrix}$.
$$AB=\begin{pmatrix}
1 & 2 & 3 \\
4 & 5 & 6 \\
7 & 8 & 9
\end{pmatrix}\begin{pmatrix}
1 & 2 \\
3 & 4 \\
5 & 6
\end{pmatrix}=\begin{pmatrix}
c_{11} & c_{12} \\
c_{21} & c_{22} \\
c_{31} & c_{32}
\end{pmatrix}$$ To calculate the element $c_{ij}$ we have to multiply the $i$-th row of $A$ with the $j$-th column of $B$, as an inner product.
So, we get the following elements:
$$c_{11}=1\cdot 1+2\cdot 3+3\cdot 5=1+6+15=22 \\
c_{12}=1\cdot 2+2\cdot 4+3\cdot 6=2+8+18=28 \\
c_{21}=4\cdot 1+5\cdot 3+6\cdot 5=4+15+30=49 \\
c_{22}=4\cdot 2+5\cdot 4+6\cdot 6=8+20+36=64 \\
c_{31}=7\cdot 1+8\cdot 3+9\cdot 5=7+24+45=76 \\
c_{32}=7\cdot 2+8\cdot 4+9\cdot 6=14+32+54=100$$ Therefore, the result is the following:
22 & 28 \\
49 & 64 \\
76 & 100
\end{pmatrix}$$
To multiply AB, all rows of A are multiplied with all columns of B.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
