How Should We Think About Quantum Mechanics?
In summary: The fact that the electron has been put in a superposition state, but the measurement device is never in a superposition state, is what is called an "irreversible process" in thermodynamics. This is what we would call a "measurement" in quantum mechanics.In summary, the measurement process in quantum mechanics involves a measurement device and an object being measured. The measurement device takes on a state corresponding to the result of the measurement performed on the object, and this process is irreversible. This process is what we refer to as a "measurement" in quantum mechanics. The concept of "wavefunction collapse" is a controversial one, with some interpretations of quantum mechanics suggesting that it does not actually happen as a physical process but rather
AlfieD
68
Greetings people of Physics,
How should we think about quantum mechanics? For example, what is meant by a "measurement" in quantum mechanics? Does "wavefunction collapse" actually happen as a physical process? If so, how, and under what conditions? If not, what happens instead?
Kind Regards,
AlfieD
Those are interesting questions which have been covered copiously here and elsewhere - besides asking in this thread, what have you done to try to answer them?
If we know this, then we can better tailor the answers to you.
Thank you.
Thank you.
Simon, if you've read my other reply to your comment (link is at the bottom of the page) then you will know that I have not done much in terms of answering these questions. However, unlike my endeavours in finding out the answer to my other question, I have performed a Google search on this:
https://www.google.co.uk/search?q=What+is+a+measurement+in+quantum+mechanics&rlz=1C1CHFX_enGB500GB500&oq=What+is+a+measurement+in+quantum+mechanics&aqs=chrome.0.57.11695j0&sourceid=chrome&ie=UTF-8#rlz=1C1CHFX_enGB500GB500&sclient=psy-ab&q=what+is+a+measurement+in+quantum+mechanics&oq=What's+a+measurement+in+quantum+&gs_l=serp.1.0.0i22i30l3.10811.21281.0.25033.46.31.7.8.11.0.91.1875.31.31.0...0.0.0..1c.1.15.psy-ab.byGs_5jHtVo&pbx=1&bav=on.2,or.r_qf.&bvm=bv.47380653,d.d2k&fp=9a303c08cdeb5d94&biw=1920&bih=971
and taken information accordingly; I know do not need to know what a measurement is in Quantum Mechanics. However, I still don't understand whether or not "wavefunction collapse" happens as a physical process and, if it does, under what conditions, and, if not, what happens then?
https://www.physicsforums.com/showthread.phpt=695536
Kind Regards,
AlfieD
Simon Bridge said:
Those are interesting questions which have been covered copiously here and elsewhere...
...and never answered to everyone's satisfaction.
Here's an extremely boiled-down version of an answer to your question ("What is the measurement process?"). Though your question is a very big question that you should be more specific on, I think this explanation is the best way to get started thinking about these ideas.The measurement process involves two objects: the object being measured and the measurement device. The object being measured is arbitrary; let's call it "the sample." The measurement device can be thought of as the kind you see in everyday experience (a multimeter, oscilloscope, photomultiplier tube, etc.)--a macroscopic object which has different "pointer" states; i.e. a macroscopic device which takes on a state corresponding to the result of the measurement performed on the sample, such that a human looking at the device can tell what state it's in. In the spirit of quantum mechanics, we could write the measurement device's state as a quantum state, just like any other quantum system.
Now let's focus on a specific example to make everything concrete. Let's say that the subject is an electron, and suppose we have a measurement device which measures the electron's spin. We will write the electron's state [itex]\left |\psi \right \rangle_e[/itex] as a linear combination of up and down states (with respect to the z-axis): [itex]\left |\psi \right \rangle_e = a\left |\uparrow \right \rangle_e+b\left |\downarrow \right \rangle_e[/itex].
Now the measurement device, described by a state [itex]\left |\phi \right \rangle_m [/itex] is one that starts out in some neutral state [itex]\left |\phi \right \rangle_m = \left |0 \right \rangle_m [/itex]and then changes its state indicating whether the electron was spin up or spin down--if it sees the electron as spin up, the measurement device's state becomes [itex]\left |\phi \right \rangle_m = \left |\uparrow \right \rangle_m [/itex], whereas if it sees the electron as spin down, the measurement device's state becomes [itex]\left |\phi \right \rangle_m = \left |\downarrow \right \rangle_m [/itex]As an example, let's write down how the measurement device would measure an electron which happens to be in the spin up state: Before the measurement, the electron-measurement device system is in the state
[itex]\left |\psi \right \rangle_e\left |\phi \right \rangle_m = \left |\uparrow \right \rangle_e\left |0 \right \rangle_m[/itex]
After the measurement is made, the measurement device reflects the electron's state.
[itex]\left |\psi \right \rangle_e\left |\phi \right \rangle_m = \left |\uparrow \right \rangle_e\left |\uparrow \right \rangle_m[/itex]
This particular measurement process can be written in summary as:
[itex]\left |\uparrow \right \rangle_e\left |0 \right \rangle_m \rightarrow \left |\uparrow \right \rangle_e\left |\uparrow \right \rangle_m[/itex]
Now suppose we can prepare the electron in a state such that it is in a superposition made of equal parts up spin and down spin (relative to the z axis. This can be prepared by measuring the spin along the x-axis first.)
[itex]\left |\psi \right \rangle_e = \frac{1}{\sqrt{2}}\left (\left |\uparrow \right \rangle_e+\left |\downarrow \right \rangle_e \right )[/itex]
What happens when the measurement device tries to measure this state?
According to Schrodinger evolution (forgetting about collapse for the moment), and moreover the principle of superposition, we could easily see the following evolution should happen (absent collapse):
[itex]
\left |\psi \right \rangle_e \left |\phi \right \rangle_m = \frac{1}{\sqrt{2}}\left (\left |\uparrow \right \rangle_e+\left |\downarrow \right \rangle_e \right )\left |0 \right \rangle_m\rightarrow\frac{1}{\sqrt{2}}\left (\left |\uparrow \right \rangle_e\left |\uparrow \right \rangle_m+\left |\downarrow \right \rangle_e\left |\downarrow \right \rangle_m \right )[/itex]
However, in subjective experience, when we look at a measuring device, we never see it in the superposition of states above. All we see is either [itex]\left |\uparrow \right \rangle_e\left |\uparrow \right \rangle_m[/itex] or [itex]\left |\downarrow \right \rangle_e\left |\downarrow \right \rangle_m[/itex]. Somewhere along the lines, one part of the quantum state gets thrown out.
This modeling of the measurement process and the apparent contradiction is due to Von Neumann. Though this argument at first appears to support the objective reality of wavefunction collapse, some deeper reflection on it shows that it's just the same as what would happen in the many-worlds interpretation (no collapse). For that argument, watch Sidney Coleman's lecture "Quantum Physics In Your Face" which is available on the Harvard website.
It's a good idea to use the resources you have at hand before asking questions of others - that way you can be more specific.
The questions you have asked are central questions in whole physics courses at college level and aspects of them form active areas of research. From your reply in another thread, you are at A-level, so any answer you get here that you can understand at that level is going to be unsatisfactory. Don't sweat it - it takes time to learn these things.
I now do not need to know what a measurement is in Quantum Mechanics.
Ah well done: what did you discover? Can you explain it to someone else?
The "collapse" of the wavefunction is probably easiest to understand as a kind-of narrative fiction that helps us talk about systems involving wavefunctions. It is certainly not considered a physical process.
Richard Feynman describes it as similar to the way ancient astronomers used to predict eclipses by moving stones or nuts between bowls.
You will probably benefit from his lectures series on QED:
http://vega.org.uk/video/subseries/8
A measurement in quantum mechanics is any interaction of any kind that conveys information as a form of detection, best described as anything that gives you information. And information is what allows you to narrow your choices, or at least refine your probabilities.
I'm currently on Part 2. Thanks for the link!
Those Feynman lectures are also available as a book titled "QED: The strange theory of light and mattter".
Thanks, I'll check it out!
FAQ: How Should We Think About Quantum Mechanics?
What is quantum mechanics?
Quantum mechanics is a branch of physics that studies the behavior of particles at the atomic and subatomic levels. It is based on the principles of quantum theory, which describe the behavior of matter and energy at a microscopic scale.
How does quantum mechanics differ from classical mechanics?
Classical mechanics is based on the laws of motion and gravity, while quantum mechanics takes into account the wave-particle duality of matter and energy. It also introduces concepts such as superposition and uncertainty, which do not exist in classical mechanics.
What are the implications of quantum mechanics?
Quantum mechanics has many practical applications in fields such as electronics, computing, and cryptography. It also challenges our understanding of the nature of reality and raises philosophical questions about determinism and free will.
How do we think about the paradoxes of quantum mechanics?
There are many paradoxes in quantum mechanics, such as the Schrödinger's cat thought experiment and the measurement problem. These paradoxes challenge our classical understanding of the world and have led to various interpretations and theories within the quantum realm.
How can we apply the principles of quantum mechanics in our daily lives?
While quantum mechanics may seem abstract and removed from our everyday experiences, it has many practical applications. For example, it is used in the development of new technologies, such as quantum computers and sensors, and in medical imaging techniques like MRI.
