How signal is transmitted through RCA cable
In summary, the conversation discusses how signals are transmitted through a single wire in a simple RCA cable. It is explained that the cable has two conductors, an inner red wire and an outer braid, which together create a circuit. The purpose and function of the black ground wire is also mentioned, with the possibility of a ground to ground connection affecting the signal quality. It is noted that the case of the connector may also play a role in grounding the signal. In conclusion, the conversation emphasizes that there is no magic involved in the transmission of signals through a single wire, and the presence or absence of a ground wire can affect the quality of the signal.
MarkWW
How signal is transmitted through only one wire (red) of simple RCA cable?
What is use and how works ground wire (black)?
There are TWO conductors; the inner (red) and the outer braid. Together, they give you a circuit.
Cable transmit signal(sound) without black wire, I tested it.
That is probably because there was another ground to ground connection present.
It may have been the other stereo channel, or through common earthing.
In your picture there is no "black wire' visible so it may be that there's a connection via the screen. The most likely explanation is that the case of the connector is connected to the Ground / case / Earth of the source of audio and the connector at the other end is connected to the ground at the amplifier (or whatever). So there is an 'unofficial' path joining the signal grounds at both ends together and making up the circuit. You may hear a difference in the sound quality with and without the black wire connected. Without a connection, there will almost certainly be some pickup of hum etc from the long path (possibly via the mains earth.
There ain't any magic at work here. :wink:
Edit: @Baluncore: Snap.
Thanks to everyone.
Related to How signal is transmitted through RCA cable
1. How does a RCA cable transmit a signal?
An RCA (Radio Corporation of America) cable transmits a signal through a series of electrical connections. The signal is carried through two separate wires, one for the left audio channel and one for the right audio channel. The signal is then amplified by the device it is connected to, such as a TV or audio receiver.
2. What type of signal does a RCA cable transmit?
A RCA cable transmits an analog signal, meaning that it carries a continuous electrical signal that can vary in amplitude and frequency. This is different from a digital signal, which is made up of binary code (0s and 1s).
3. How far can a RCA cable transmit a signal?
The maximum distance a RCA cable can effectively transmit a signal depends on various factors such as the quality of the cable, the strength of the signal, and any interference. In general, a RCA cable can transmit a signal up to 50 feet without any noticeable degradation in quality.
4. Can a RCA cable transmit high-definition signals?
No, a RCA cable is not capable of transmitting high-definition signals. It was originally designed for analog audio signals and is not able to handle the higher bandwidth required for high-definition video. For high-definition signals, it is recommended to use an HDMI cable or other digital connection.
5. What are some common issues that can affect the transmission of a RCA signal?
Some common issues that can affect the transmission of a RCA signal include loose connections, damaged cables, and interference from other electronic devices. It is important to ensure that the cable is securely connected and in good condition to ensure the best quality signal. Placing the cable away from other electronic devices can also help minimize interference.
  • Electrical Engineering
