How Tall Is The Building? - Projectile Motion
In summary, a 0.43 kg rock is projected from the edge of the top of a building with an initial velocity of 9.2 m/s at an angle 45◦ above the horizontal. Due to gravity, the rock strikes the ground at a horizontal distance of 14.9 m from the base of the building. Using the equation d=Vot + 1/2at^2, we can find the time of the projectile's motion by setting the horizontal displacement, 14.9 m, equal to the horizontal velocity, 9.2 cos(45), multiplied by time, and solving for t. This results in a time of 2.28 seconds. Then, using the equation d=V
Osbourne_Cox
50
1. A 0.43 kg rock is projected from the edge of the top of a building with an initial velocity of 9.2 m/s at an angle 45◦ above the horizontal. Due to gravity, the rock strikes the ground at a horizontal distance of 14.9 m from the base of the building.
How tall is the building? Assume the ground is level and that the side of the building is vertical. The acceleration of gravity is 9.8 m/s2 .
I've broken the problem down into halves. I've solved the top half ( the part of the motion equal in height to the roof ) but don't know how to get the second half ( the part of the motion after the rock is past the point level with the roof. ) Have I even gone about this right?
First half:
Vxi=9.2cos45=6.51m/s Vyi=9.2sin45=6.51m/s
delta t=(Vfy-Viy)/g =1.33 s
delta d=Vix(delta t) =8.65 m
Second half: (Not sure if right)
Vix=6.51cos45=4.6m/s Viy=6.51sin45=4.6m/s
Now I am stuck!
You can fit all the information for the Y axis into one equation:
d=Vot + 1/2at2
So d is your vertical displacement, Vo your initial velocity, etc. Make sure you use proper signs, otherwise this will fail horribly.
Graphing is never accurate, so let's go about this algebraically.
The things you don't know are t, and d.
So if you find t you can find d.
You know the horizontal displacement, and the horizontal velocity, so by using:
Dx=Vxt
you can solve for t, then put it into the first equation.
Your resulting displacement should be negative. The absolute value of this is the height of the building.
If you did move d over and make the whole thing a quadratic equation, the graph would exactly model this setup.
Give it a try.
[tex]\vec{a}(t)=\left(\begin{array}{c} 0 \\-g \end{array}\right)[/tex]
by integrating this expression we get:
[tex]\vec{v}(t)=\left(\begin{array}{c} v_0\cos\alpha \\-gt +v_0\sin\alpha\end{array}\right)[/tex]
and integrating a second time gives
[tex]\left(\begin{array}{c}x(t) \\y(t)\end{array}\right)=\left(\begin{array}{c} v_0t\cos\alpha \\- \frac 1 2 gt^2 +v_0t\sin\alpha +h\end{array}\right)[/tex]
hence
[tex]y=-\frac{g}{2v_0^2 \cos^2 \alpha} x^2 + x\tan \alpha +h[/tex]
and finally
[tex]y=0 \Rightarrow h= \frac{g}{2v_0^2 \cos^2 \alpha} x^2 - x\tan \alpha}[/tex]
[tex]v_0=9.2 m.s^{-1},\alpha=45^{\circ}{, x=14.9m[/tex]
Okay, so the values I put in for Dx and Vx are 8.65 m and 4.6 or 6.51?
What is the X component of 9.2 m/s at 45 degrees?
9.2cos45 = 6.51
Where did you pull 4.6 from?
Ha, the second part of my first attempt at this...I didn't know if I should even have done that. Sorry.
No need to apologize.
Just follow the steps I outlined and you'll get it.
If you want me to explain more feel free to ask questions.
So, I get 1.33 s for t. Now, putting that value for t into the first equation, I get 3.57 for d. I thought it was supposed to be negative?
I got 2.218 seconds.
Did you do your algebra correctly?
The displacement I got was 38.9 meters.
I should have been more specific, if you're putting in a distance then it should be negative, but since you're finding it it'll come out positive.
Okay, maybe I'm still not understanding. I did this:
Dx=Vxt
8.65m=6.51m/s(t)
8.65m/6.51m/s=t
1.33=t
Was I supposed to?
A 0.43 kg rock is projected from the edge of the top of a building with an initial velocity of 9.2 m/s at an angle 45o above the horizontal. Due to gravity, the rock strikes the ground at a horizontal distance of 14.9 m from the base of the building.
Dx should be 14.9
Vx should be 9.2cos(45)
Dx=Vxt
So to find time
t=Dx/Vx
Yes, now I get 2.28 s
So shove it into the other equation and see what you get.
I get d= -4.69
Check your calculations. I got -10.63988816.
I still can't get that as an answer.
Does your equation look like this?
d = 9.2cos(45)t + .5(-9.8)t2
d = 6.50538(2.28) + -4.9(2.28)2
d = 14.83227 + (-25.47216)
Oh, I just used the initial velocity, not the x component of it.
AGH! NO! WRONG!
You use the Y component, the only equation for X velocity in a projectile motion scenario is Dx = Vxt
That is solving for parts of the Y component. In this case the X and Y components just happen to be the same because of the angle.
My bad, it should've said sin(45).
d = 9.2sin(45)t + .5(-9.8)t2
Oh, okay. So yes, now I get the same answer as you. My apologies, I am very slow at this stuff.
No worries. I didn't get this stuff much faster when I was learning it.
Argh. Quest says it isn't the right answer.
Ask your teacher about it, that method should work...
FAQ: How Tall Is The Building? - Projectile Motion
What is projectile motion?
Projectile motion is the motion of an object through the air that is affected by gravity. This type of motion is characterized by a horizontal and vertical component, where the object moves in a parabolic path.
How does projectile motion relate to the height of a building?
The height of a building can be determined using projectile motion because the object (such as a ball or projectile) will follow a parabolic path when thrown or launched from the top of the building.
What factors affect the accuracy of determining the height of a building using projectile motion?
The factors that affect the accuracy of determining the height of a building using projectile motion include air resistance, wind speed, angle of launch, and the initial velocity of the object.
Can projectile motion be used to measure the height of any building?
Yes, projectile motion can be used to measure the height of any building as long as the object is launched from the top of the building and the above mentioned factors are taken into consideration.
What other applications does projectile motion have in science and engineering?
Projectile motion has many applications in science and engineering, such as in ballistics, sports, and transportation. It is also used in designing roller coasters, launching satellites, and studying the motion of planets and other celestial bodies.
