anti_matter
- 2
I have a fan in crawlspace that I can turn on to draw in fresh air. This could reduce the relative humidity by raising the air temperature, and lowering the moisture density. However, air temperature doesn't go up very much because the dirt and foundation wall tend to keep the air at around 55 degree (F).
Given the outside air temperature and RH, and the crawlspace air temperature and RH, how can I determine whether turning on the fan would reduce RH?
I could not find a formula to calculate RH at a second temperature given RH at one temperature.
I did find some formulas about vapor density and dew points. I just am not sure what remains constant when air travels to a cooler area. Does the water vapor density remains the same, or does dew point remain the same?
