How the velocity of rain relative to the driver in car increases?
In summary, the velocity of rain with respect to the man is calculated by subtracting the velocity of the car with respect to the ground from the velocity of the rain with respect to the ground. This is not a regular addition, but rather a vector addition. The "wrt" in the equation indicates that only the horizontal components are to be used. However, more information from the OP is needed to fully understand the problem.
Krishna Behera
How does the velocity of the rain with respect to the car get added up? Velocity of rain with respect to man is given by the (velocity of rain wrt ground - the velocity of car wrt ground). Here it's not being added up!
How is what you just described not an addition of velocities?
You mean because there is a minus sign? Then write it like this:
velocity of rain wrt car = velocity of rain wrt ground + the velocity of ground wrt car
No. You need to do vector addition not regular addition.
I think the "wrt" part is basically saying to only use the horizontal components.
wrt is "with respect to" and has nothing to do with projecting out the horizontal components.
I think we need the OP to come back with more info on the problem.
That is of course true and how my post #3 should be interpreted.
FAQ: How the velocity of rain relative to the driver in car increases?
1. What causes the velocity of rain relative to the driver in a car to increase?
The velocity of rain relative to the driver in a car increases due to the motion of the car. As the car moves forward, it creates a relative motion between the raindrops and the driver, causing the velocity of the raindrops to increase.
2. Does the velocity of the car affect the velocity of rain relative to the driver?
Yes, the velocity of the car directly affects the velocity of rain relative to the driver. The faster the car is moving, the higher the velocity of the raindrops will be relative to the driver.
3. How does the angle of the windshield affect the velocity of rain relative to the driver?
The angle of the windshield can affect the velocity of rain relative to the driver. If the windshield is angled more horizontally, it will cause the raindrops to hit the windshield at a faster rate, increasing the velocity of the rain relative to the driver. However, if the windshield is angled more vertically, the raindrops may slide off the windshield, causing a lower velocity of rain relative to the driver.
4. What happens to the velocity of rain relative to the driver when the car is stopped?
When the car is stopped, there is no relative motion between the raindrops and the driver. Therefore, the velocity of rain relative to the driver will be zero.
5. Can the velocity of rain relative to the driver vary depending on the speed of the raindrops?
Yes, the velocity of rain relative to the driver can vary depending on the speed of the raindrops. If the raindrops are falling at a faster rate, the velocity of rain relative to the driver will also be higher, and vice versa.
