RDM70
- 2
- TL;DR Summary
- Any object in motion has angular momentum relative to a fixed axis does it also necessarily have linear momentum.
Suppose a bar is fixed to an axle at one one so that it can pivot. The bar is initially motionless, but is set rotating about it's axle when impacted by a ball. (The ball does not strike the bar at it's pivot point.) Suppose the collision is such that the bar is set rotating and the ball is motionless after the moment of impact. (A collision with the ball traveling perpendicular to the long axis of the bar and transferring all of it's energy to the bar at the moment of impact.)
Before the impact, the ball had angular momentum with respect to the bar's pivot point. If all of that angular momentum is transferred to the bar, and the ball's motion is stopped. The ball then has no angular momentum after the impact.
Question: Before the impact, the ball was traveling in a straight line with no forces acting on it. It had angular momentum with respect to some arbitrary axis. Did it also have linear momentum? If so, what happened to the ball's linear momentum?
