- #36
Svein
- 805
nicy12 said:Those in red is what "negative currents" I am talking about.
How did you invent those? When the LDR has a value of 160kΩ, the voltage at the first base is below the turn-on point and no current enters the base. If you could pull a current out of the base (that is what you are implying with negative currents), then no current would flow in the transistor. It gets worse. In your two circuits you draw both sets of current with the same direction and you name them positive in one instance and negative in the other. Do you mean that the transistors suddenly start to act as voltage sources, pushing current back into the battery?
