How to add elements in a Java swing List Box
In summary: This method is called from within the constructor to initialize the form. * WARNING: Do NOT modify this code. The content of this method is always * regenerated by the Form Editor. */ //int i; public JavaListAddDelEdit() { //initComponents(); //model = new DefaultListModel(); //list = new JList<String>(model); //i=0; } /** * This
zak100
462
Hi,
I am using NetBeans 8.1. I want to add elements in a list Box on a Button press. My code would read text from textField & then insert into list box:
private void button1ActionPerformed(java.awt.event.ActionEvent evt) {
// TODO add your handling code here:
String str=jTF.getText();
list.??
I don't know the list box method for this purpose. My variables are:
private javax.swing.JButton button1;
private javax.swing.JButton button2;
private javax.swing.JButton button3;
private javax.swing.JLabel jLabel1;
private javax.swing.JPanel jPanel1;
private javax.swing.JScrollBar jScrollBar1;
private javax.swing.JScrollPane jScrollPane1;
private javax.swing.JTextField jTF;
private javax.swing.JList<String> list;
From netBeans, i found following methods:add(Component comp)
add(PopupMenu comp)
add(Component comp, Object o)
add(String str, Component comp)<----------
add(Component comp, Object o, int i)
The method :
can be used but what is the value of:
comp object??
Some body please guide me.
Zulfi.
Technology news on Phys.org
Hi,
Thanks for your response. I am doing it for JList. I have made some changes:
added a variable i & modified the constructor to:
int i;
initComponents();
i=0;
Wrote the add button handler: private void button1ActionPerformed(java.awt.event.ActionEvent evt) {
model.add(i, str);
i++;
added a declaration for:
DefaultListModel model;
But when i execute the program, I am getting following er
One or more projects were compiled with error:
When i press cancel, i am directed to this
run:
C:\Users\HP\AppData\Local\NetBeans\Cache\8.1\executor-snippets\run.xml:48:
Cancelled by user
BUILD FAILED (total time: 1 minute 25 seconds)
When i pressed the above line, i am directed to:
<translate-classpath classpath="${classpath}" targetProperty="classpath-translated" />
Kindly guide me how to fix this problem.
Zulfi.
I'm going to take a guess that the problem is your i variable. You don't show all of your code, but it looks like i is a variable in whatever class you have defined, that has the JavaListAddDelEdit() method and the button1ActionPerformed() handler. I suspect that since you haven't specified otherwise in your declaration for i, its access level is private, so when you attempt to increment i in JavaListAddDelEdit() and button1ActionPerformed(), the compiler quits and issues the error.
In addition, when you post code, please use [code] tags around your code, like this:
[code=java]
// Your java code
[/code]
With code tags here is how one of your methods should look:
Java:
     initComponents();
     i=0;
Hi,
I am getting error with DefaultListModel. I am using java NetBeans
Code:
* To change this license header, choose License Headers in Project Properties.
* To change this template file, choose Tools | Templates
* and open the template in the editor.
package jListAddDelEdit;
* @author HP
public class JavaListAddDelEdit extends javax.swing.JFrame {
public DefaultListModel<String> model = new DefaultListModel<>();
     * Creates new form JavaListAddDelEdit
    //int i;
        initComponents();
        //i=0;
     * This method is called from within the constructor to initialize the form.
    @SuppressWarnings("unchecked")
    // <editor-fold defaultstate="collapsed" desc="Generated Code">
    private void initComponents() {
        jPanel1 = new javax.swing.JPanel();
        jLabel1 = new javax.swing.JLabel();
        jTF = new javax.swing.JTextField();
        jScrollPane1 = new javax.swing.JScrollPane();
        list = new javax.swing.JList<>();
        button1 = new javax.swing.JButton();
        button2 = new javax.swing.JButton();
        button3 = new javax.swing.JButton();
        jScrollBar1 = new javax.swing.JScrollBar();
        setDefaultCloseOperation(javax.swing.WindowConstants.EXIT_ON_CLOSE);
        setTitle("Java List Add Delete Edit Elements");
        jLabel1.setText("Item Name");
        list.setModel(new javax.swing.AbstractListModel<String>() {
            String[] strings = { "Item 1", "Item 2", "Item 3", "Item 4", "Item 5" };
            public int getSize() { return strings.length; }
            public String getElementAt(int i) { return strings[i]; }
        jScrollPane1.setViewportView(list);
        button1.setText("Add");
        button1.addActionListener(new java.awt.event.ActionListener() {
            public void actionPerformed(java.awt.event.ActionEvent evt) {
                button1ActionPerformed(evt);
        button2.setText("Delete");
        button2.addActionListener(new java.awt.event.ActionListener() {
                button2ActionPerformed(evt);
        button3.setText("Edit");
        button3.addActionListener(new java.awt.event.ActionListener() {
                button3ActionPerformed(evt);
        javax.swing.GroupLayout jPanel1Layout = new javax.swing.GroupLayout(jPanel1);
        jPanel1.setLayout(jPanel1Layout);
        jPanel1Layout.setHorizontalGroup(
            jPanel1Layout.createParallelGroup(javax.swing.GroupLayout.Alignment.LEADING)
            .addGroup(jPanel1Layout.createSequentialGroup()
                .addGroup(jPanel1Layout.createParallelGroup(javax.swing.GroupLayout.Alignment.LEADING, false)
                    .addGroup(javax.swing.GroupLayout.Alignment.TRAILING, jPanel1Layout.createSequentialGroup()
                        .addContainerGap()
                        .addComponent(jScrollPane1)
                        .addPreferredGap(javax.swing.LayoutStyle.ComponentPlacement.RELATED)
                        .addComponent(jScrollBar1, javax.swing.GroupLayout.PREFERRED_SIZE, javax.swing.GroupLayout.DEFAULT_SIZE, javax.swing.GroupLayout.PREFERRED_SIZE))
                        .addComponent(jLabel1)
                        .addGap(18, 18, 18)
                        .addComponent(jTF, javax.swing.GroupLayout.PREFERRED_SIZE, 220, javax.swing.GroupLayout.PREFERRED_SIZE)))
                .addGap(18, 18, Short.MAX_VALUE)
                    .addComponent(button2, javax.swing.GroupLayout.DEFAULT_SIZE, javax.swing.GroupLayout.DEFAULT_SIZE, Short.MAX_VALUE)
                    .addComponent(button1, javax.swing.GroupLayout.DEFAULT_SIZE, javax.swing.GroupLayout.DEFAULT_SIZE, Short.MAX_VALUE)
                    .addComponent(button3, javax.swing.GroupLayout.DEFAULT_SIZE, javax.swing.GroupLayout.DEFAULT_SIZE, Short.MAX_VALUE))
                .addGap(0, 9, Short.MAX_VALUE))
        jPanel1Layout.setVerticalGroup(
                .addContainerGap()
                .addGroup(jPanel1Layout.createParallelGroup(javax.swing.GroupLayout.Alignment.BASELINE)
                    .addComponent(jTF, javax.swing.GroupLayout.PREFERRED_SIZE, javax.swing.GroupLayout.DEFAULT_SIZE, javax.swing.GroupLayout.PREFERRED_SIZE)
                    .addComponent(button1))
                    .addComponent(jScrollPane1, javax.swing.GroupLayout.DEFAULT_SIZE, 217, Short.MAX_VALUE)
                        .addComponent(button2)
                        .addComponent(button3))
                    .addComponent(jScrollBar1, javax.swing.GroupLayout.DEFAULT_SIZE, javax.swing.GroupLayout.DEFAULT_SIZE, Short.MAX_VALUE))
                .addContainerGap(21, Short.MAX_VALUE))
        javax.swing.GroupLayout layout = new javax.swing.GroupLayout(getContentPane());
        getContentPane().setLayout(layout);
        layout.setHorizontalGroup(
            layout.createParallelGroup(javax.swing.GroupLayout.Alignment.LEADING)
            .addGroup(layout.createSequentialGroup()
                .addContainerGap()
                .addComponent(jPanel1, javax.swing.GroupLayout.DEFAULT_SIZE, javax.swing.GroupLayout.DEFAULT_SIZE, Short.MAX_VALUE)
                .addContainerGap())
        layout.setVerticalGroup(
            .addGroup(javax.swing.GroupLayout.Alignment.TRAILING, layout.createSequentialGroup()
                .addContainerGap()
                .addContainerGap())
        pack();
    }// </editor-fold>
        model.addElement( str);
        list.setModel(model);
       // i++;
    private void button2ActionPerformed(java.awt.event.ActionEvent evt) {
    private void button3ActionPerformed(java.awt.event.ActionEvent evt) {
     * @param args the command line arguments
    public static void main(String args[]) {
        /* Set the Nimbus look and feel */
        //<editor-fold defaultstate="collapsed" desc=" Look and feel setting code (optional) ">
        /* If Nimbus (introduced in Java SE 6) is not available, stay with the default look and feel.
         * For details see http://download.oracle.com/javase/tutorial/uiswing/lookandfeel/plaf.html
        try {
            for (javax.swing.UIManager.LookAndFeelInfo info : javax.swing.UIManager.getInstalledLookAndFeels()) {
                if ("Nimbus".equals(info.getName())) {
                    javax.swing.UIManager.setLookAndFeel(info.getClassName());
                    break;
        } catch (ClassNotFoundException ex) {
            java.util.logging.Logger.getLogger(JavaListAddDelEdit.class.getName()).log(java.util.logging.Level.SEVERE, null, ex);
        } catch (InstantiationException ex) {
        } catch (IllegalAccessException ex) {
        } catch (javax.swing.UnsupportedLookAndFeelException ex) {
        //</editor-fold>
        /* Create and display the form */
        java.awt.EventQueue.invokeLater(new Runnable() {
            public void run() {
                new JavaListAddDelEdit().setVisible(true);
    // Variables declaration - do not modify
    // End of variables declaration
I am getting the following error message:
Exception in thread "AWT-EventQueue-0" java.lang.RuntimeException: Uncompilable source code - cannot find symbol
symbol: class DefaultListModel
at jListAddDelEdit.JavaListAddDelEdit.<init>(JavaListAddDelEdit.java:13)
at jListAddDelEdit.JavaListAddDelEdit$5.run(JavaListAddDelEdit.java:186)
at java.awt.event.InvocationEvent.dispatch(InvocationEvent.java:311)
at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:756)
at java.awt.EventQueue.access$500(EventQueue.java:97)
at java.awt.EventQueue$3.run(EventQueue.java:709)
at java.awt.EventQueue$3.run(EventQueue.java:703)
at java.security.AccessController.doPrivileged(Native Method)
at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(ProtectionDomain.java:76)
at java.awt.EventQueue.dispatchEvent(EventQueue.java:726)
at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:201)
at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:116)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:105)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:101)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:93)
at java.awt.EventDispatchThread.run(EventDispatchThread.java:82)
BUILD SUCCESSFUL (total time: 2 seconds)
Somebody please guide m.
Zulfi.
zak100 said:
Java:
It looks like you just stuck the 2nd line in here. The problem is that there is no definition for a DefaultListModel class, and that's what the first error in your list of errors is telling you.
You need an import statement for DefaultListModel or you need to specify where its comes from as in java.swing.DefaultListModel
Hi,
Thanks my friend. I have added the import statement. Its not giving any error now but its not adding elements in the list. Its retrieving the value from textField & displaying it using JOptionPane but not adding it in the listBox. My modified code is:
Java:
import javax.swing.*;
* @author HP
    //int i;
        initComponents();
        //i=0;
                        .addContainerGap()
                        .addGap(18, 18, 18)
                .addContainerGap()
                .addContainerGap()
                .addContainerGap())
                .addContainerGap()
                .addContainerGap())
        pack();
    }// </editor-fold>
        JOptionPane.showMessageDialog(null,str);
       // i++;
        try {
                    break;
        //</editor-fold>
            public void run() {
Zulfi.
zak100 said:
Java:
        // i++;
As far as I can tell, the method above needs to insert the string into your list variable, and this would likely happen in the method above.
Hi,
I have added the JOptionPane for the sake of debugging. Its displaying the value retrieved from JTextField but why its not displaying it in JListBox is a programming error. Please check the following method:
privatevoid button1ActionPerformed(java.awt.event.ActionEvent evt){
// i++;
Zulfi.
jedishrfu said:
Netbeans 8.1 and earlier have a debug facility that can help you discover what is going on with your code. We can't simply look at it each time you make a change and then tell you what is going on and why it isn't working.
Excellent advice. If you're writing code in any language, it pays to get familiar with whatever debugger is present. Virtually all modern programming languages have some sort of debugger that you can use to set a breakpoint and inspect the value of a given variable.
Hi,
I have checked the value of list & model objects
list type(JList) value(1700)
model type(DefaultListModel) value(1619)
They are negative, so they are correct. str is also correct. So which other value should i check?
Zulfi.
zak100 said:
Hi,
Zulfi.
How do you figure they're negative? 1700 and 1619 are positive, but I suspect these values either represent addresses or if not addresses, just uninitialized "garbage" values.You have a list variable. What methods are available on a JList object to insert values into it?
Hi,
I mean its not negative so its correct object address. I tried this:
list.add(model,1);
// i++;
but its giving errors:
thread "AWT-EventQueue-0" java.lang.RuntimeException: Uncompilable source code - Erroneous sym type: javax.swing.JList.add
at jListAddDelEdit.JavaListAddDelEdit.button1ActionPerformed(JavaListAddDelEdit.java:143)
at jListAddDelEdit.JavaListAddDelEdit.access$000(JavaListAddDelEdit.java:12)
at jListAddDelEdit.JavaListAddDelEdit$2.actionPerformed(JavaListAddDelEdit.java:59)
at javax.swing.AbstractButton.fireActionPerformed(AbstractButton.java:2022)
at javax.swing.AbstractButton$Handler.actionPerformed(AbstractButton.java:2348)
at javax.swing.DefaultButtonModel.fireActionPerformed(DefaultButtonModel.java:402)
at javax.swing.DefaultButtonModel.setPressed(DefaultButtonModel.java:259)
at javax.swing.plaf.basic.BasicButtonListener.mouseReleased(BasicButtonListener.java:252)
at java.awt.Component.processMouseEvent(Component.java:6535)
at javax.swing.JComponent.processMouseEvent(JComponent.java:3324)
at java.awt.Component.processEvent(Component.java:6300)
at java.awt.Container.processEvent(Container.java:2236)
at java.awt.Component.dispatchEventImpl(Component.java:4891)
at java.awt.Container.dispatchEventImpl(Container.java:2294)
at java.awt.Component.dispatchEvent(Component.java:4713)
at java.awt.LightweightDispatcher.retargetMouseEvent(Container.java:4888)
at java.awt.LightweightDispatcher.processMouseEvent(Container.java:4525)
at java.awt.LightweightDispatcher.dispatchEvent(Container.java:4466)
at java.awt.Container.dispatchEventImpl(Container.java:2280)
at java.awt.Window.dispatchEventImpl(Window.java:2750)
at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:758)
at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(ProtectionDomain.java:86)
at java.awt.EventQueue$4.run(EventQueue.java:731)
at java.awt.EventQueue$4.run(EventQueue.java:729)
at java.awt.EventQueue.dispatchEvent(EventQueue.java:728)
at java.awt.EventDispatchThread.run(EventDispatchThread.java:82)Zulfi.
zak100 said:
Java:
You have to specify the type of list; in other words what type of objects will go into the list?
Hi,
Thanks. I already did this in the constructor.
Java:
        initComponents();
        //i=0;
Please guide me.
Zulfi.
Hi,
Yes i saw this example, & but it does not tell how we can use it for NetBeans. Now i am trying to use it for Netbeans. I created a project & provided a Frame & then a penal & then inserted components in the panel. But i have following class signature using a project named ListBox2:
public class CListBox2 extends javax.swing.JFrame {
where as the tutorial project has following class signature:
/* ListDemo.java requires no other files. */
public class ListDemo extends JPanel implements ListSelectionListener {
I think this is the problem.
Although, I have created a Panel using NetBeans & I am putting my controls in this panel:
My variable declaration shows this:
Java:
private javax.swing.JButton jButton1;
    private javax.swing.JList<String> jList1;
When I converted the class signature into :
Java:
public class CListBox2 extends JPanel
manually, I am getting following errors:
java.lang.ExceptionInInitializerError
Caused by: java.lang.RuntimeException: Uncompilable source code - JavaListBox2.CListBox2 is not abstract and does not override abstract method valueChanged(javax.swing.event.ListSelectionEvent) in javax.swing.event.ListSelectionListener
at JavaListBox2.CListBox2.<clinit>(CListBox2.java:15)
Exception in thread "main" C:\Users\HP\AppData\Local\NetBeans\Cache\8.1\executor-snippets\run.xml:53: Java returned: 1
BUILD FAILED (total time: 1 second)
My complete NetBeans code is:
Java:
package JavaListBox2;
import java.awt.*;
import java.awt.event.*;
import javax.swing.event.*;
* @author HP
  * Creates new form CListBox2
  public CListBox2() {
  initComponents();
  private void initComponents() {  jPanel1 = new javax.swing.JPanel();
  jList1 = new javax.swing.JList<>();
  jButton1 = new javax.swing.JButton();  setDefaultCloseOperation(javax.swing.WindowConstants.EXIT_ON_CLOSE);  jList1.setModel(new javax.swing.AbstractListModel<String>() {
  public String getElementAt(int i) { return strings; }
  jScrollPane1.setViewportView(jList1);  jButton1.setText("jButton1");  javax.swing.GroupLayout jPanel1Layout = new javax.swing.GroupLayout(jPanel1);
  .addContainerGap()
  .addComponent(jScrollPane1, javax.swing.GroupLayout.PREFERRED_SIZE, 105, javax.swing.GroupLayout.PREFERRED_SIZE)
  .addGap(60, 60, 60)
  .addComponent(jButton1)
  .addContainerGap(75, Short.MAX_VALUE))
  .addGroup(jPanel1Layout.createParallelGroup(javax.swing.GroupLayout.Alignment.LEADING)
  .addContainerGap()
  .addComponent(jScrollPane1, javax.swing.GroupLayout.PREFERRED_SIZE, 190, javax.swing.GroupLayout.PREFERRED_SIZE))
  .addGap(45, 45, 45)
  .addComponent(jButton1)))
  .addContainerGap(39, Short.MAX_VALUE))
  );  javax.swing.GroupLayout layout = new javax.swing.GroupLayout(getContentPane());
  .addGap(48, 48, 48)
  .addComponent(jPanel1, javax.swing.GroupLayout.PREFERRED_SIZE, javax.swing.GroupLayout.DEFAULT_SIZE, javax.swing.GroupLayout.PREFERRED_SIZE)
  .addContainerGap(115, Short.MAX_VALUE))
  .addGap(19, 19, 19)
  .addContainerGap(41, Short.MAX_VALUE))
  );  pack();
  }// </editor-fold>  /**
  * [USER=541057]@param[/USER] args the command line arguments
   try {
  break;
  java.util.logging.Logger.getLogger(CListBox2.class.getName()).log(java.util.logging.Level.SEVERE, null, ex);
  //</editor-fold>  /* Create and display the form */
  public void run() {
  new CListBox2().setVisible(true);
   }  // Variables declaration - do not modify
Some body please guide me how can i extend my class from JPanel & implementsListSelectionListener.
Zulfi.
When I've used the Netbeans forms builder "Matisse", I don't place a lot of code inside the generated form ie I don't use the form as a basis for my program.
Instead I write a main class that instantiates the form and then links the form to my code ie I connect up listeners for any component activities in the form.
isnt netbeans providing error markers to help you resolve some of these issues you're having?
I often use the error messages and Google to find others with the same problem and usually a solution.
In your get string method you need to return a string not a string array i.e. You need to say
return strings;
zak100 said:
Java:
 public class CListBox2 extends JPanel  implementsListSelectionListener
I believe that this error occurs because you are telling the compiler that you are implementing the ListSelectionListener interface, but you aren't actually doing so.
An interface in Java is a collection of one or more method declarations or signatures. To implement an interface you have to provide definitions for all of the methods that are listed in the interface. In this case, ListSelectionListener has only one method -- valueChanged (see http://docs.oracle.com/javase/7/docs/api/javax/swing/event/ListSelectionListener.html). Your code for CListBox2 has to include a definition for a method named valueChanged.
Hi,
I have got a program from internet. There is no error, but its still not able to add elements in the list:
Java:
package jListBox4;
public class CListBox4 extends javax.swing.JFrame {
     * Creates new form CListBox4
    public CListBox4() {
        initComponents();
         DefaultListModel<String> listModel = new DefaultListModel<>();
          listModel.removeAllElements();
        listModel.addElement("USA");
        listModel.addElement("India");
        listModel.addElement("Vietnam");
        listModel.addElement("Canada");
        listModel.addElement("Denmark");
        listModel.addElement("France");
        listModel.addElement("Great Britain");
        listModel.addElement("Japan");
        //create the list
        jList = new JList<>(listModel);
        add(jList);
        this.setDefaultCloseOperation(JFrame.EXIT_ON_CLOSE);
        this.setTitle("JList Example");
        this.setSize(200,200);
        this.setLocationRelativeTo(null);
        this.setVisible(true);
        jList = new javax.swing.JList<>();
        jList.setModel(new javax.swing.AbstractListModel<String>() {
        jScrollPane1.setViewportView(jList);
                .addGap(47, 47, 47)
                .addComponent(jScrollPane1, javax.swing.GroupLayout.PREFERRED_SIZE, 117, javax.swing.GroupLayout.PREFERRED_SIZE)
                .addContainerGap(236, Short.MAX_VALUE))
                .addGap(32, 32, 32)
                .addComponent(jScrollPane1, javax.swing.GroupLayout.PREFERRED_SIZE, javax.swing.GroupLayout.DEFAULT_SIZE, javax.swing.GroupLayout.PREFERRED_SIZE)
                .addContainerGap(138, Short.MAX_VALUE))
        pack();
    }// </editor-fold>
        try {
                    break;
            java.util.logging.Logger.getLogger(CListBox4.class.getName()).log(java.util.logging.Level.SEVERE, null, ex);
        //</editor-fold>
            public void run() {
                new CListBox4().setVisible(true);
    private javax.swing.JList<String> jList;
Somebody please guide me how to add elements in the list & what's the problem with code. I am working on netBeans and i can't edit the "void initComponents() " code. Currently its showing me item 1, item2, ... item 5. Its not invoking the code written after initComponents( ) in the constructor.
Zulf.
Hi,
why my code in reply# 22 not working??
Zulfi.
zak100 said:
Hi,
Zulfi.
Not sure, but the line where you create a jList variable is probably not right-- this line:
Java:
The empty angle brackets should not be there, I don't believe. Also, I don't know what you're doing in the following line -- add(jList); --
The biggest problem I see is that you are declaring jList too many times. It should be declared only once.
This one is in the CListBox4() constructor. See the snippet I'm including for the correct way to do this.
Java:
//create the list
This one is in your initComponents method.
Java:
Here is a declaration at the bottom of your code. I haven't written any Java code for about 20 years, but I think that these declarations of private variables should be at the top, just after where your class starts, not at the bottom.
Java:
Here's a snippet of code from this page, http://docs.oracle.com/javase/tutor.../ListDemoProject/src/components/ListDemo.java, that might be helpful.
Java:
 private JList list;
 private DefaultListModel listModel;
 private static final String hireString = "Hire";
 private static final String fireString = "Fire";
 private JButton fireButton;
 private JTextField employeeName;
 public ListDemo() {
 super(new BorderLayout());
 listModel = new DefaultListModel();
 listModel.addElement("Jane Doe");
 listModel.addElement("John Smith");
 listModel.addElement("Kathy Green");
 //Create the list and put it in a scroll pane.
 list = new JList(listModel);
 list.setSelectionMode(ListSelectionModel.SINGLE_SELECTION);
 list.setSelectedIndex(0);
 list.addListSelectionListener(this);
 list.setVisibleRowCount(5);
In this sample they declare list at the top (private JList list;). Near the bottom of the code above, they allocate space for list, list = new JList(listModel);
Here's an example of a dynamically adjustable list:
http://www.cs.cf.ac.uk/Dave/HCI/HCI_Handout_CALLER/node144.html
Hi,
Thanks my friend but it does not solve my problem. Because it says that:
  • Initially the list is empty.
Actually this was the problem with the code which i was using.
However I am now able to solve this problem. I checked a video on You-tube & i got the solution. Thanks everybody. The solution lies in clearing the initially created list box & this is not mentioned in the tutorial. After creating the list box, i went to properties->model & erased the contents across this field. After that my program ran correctly. I would suggest tuning the documentation for NetBeans users.
My code corresponding to the two Buttons are:
Java:
private void jButton1ActionPerformed(java.awt.event.ActionEvent evt) {
        for (int i=0;i<5; ++i)
            model.addElement("Zulfi item" +i);
        jList1.setModel(model);
    private void jButton2ActionPerformed(java.awt.event.ActionEvent evt) {
        String str=jTextField1.getText();
        model.addElement(str);
& the constructor is:
Java:
public class JavaListBox1 extends javax.swing.JFrame {
private DefaultListModel model;
     * Creates new form JavaListBox1
    public JavaListBox1() {
        initComponents();
Variables corresponding to the components are:
Java:
    private javax.swing.JButton jButton2;
    private javax.swing.JTextField jTextField1;
Problem solved now.
Zulfi.
That's great! Thanks for the update.
Related to How to add elements in a Java swing List Box
1. How do I add an element to a Java swing List Box?
To add an element to a Java swing List Box, you can use the addElement() method. This method takes in the element you want to add as a parameter and automatically adds it to the end of the List Box.
2. Can I add multiple elements to a Java swing List Box at once?
Yes, you can add multiple elements to a Java swing List Box at once by using the add() method. This method allows you to add multiple elements at once by taking in an array of elements as a parameter.
3. How do I add elements to a specific position in a Java swing List Box?
To add an element to a specific position in a Java swing List Box, you can use the add(index, element) method. This method takes in the index where you want to add the element and the element itself as parameters.
4. How can I remove an element from a Java swing List Box?
To remove an element from a Java swing List Box, you can use the remove(element) method. This method takes in the element you want to remove as a parameter and removes it from the List Box.
5. Is it possible to clear all elements from a Java swing List Box at once?
Yes, you can clear all elements from a Java swing List Box at once by using the clear() method. This method removes all elements from the List Box and leaves it empty.
12K
