How to add HZO as an Oxide gate in Silvaco TCAD?
To simulate a Gate-All-Around FET in Silvaco TCAD using HZO (Hf0.5Zr0.5O2) as an oxide gate, specific coding guidance is needed. Users are seeking assistance with the appropriate code to incorporate HZO into their simulations. Examples from Silvaco may provide insights but do not directly address the HZO integration. The discussion emphasizes the need for clear instructions or code snippets to facilitate this process. Assistance from experienced users in the community is crucial for successful simulation setup.
mhr0003
TL;DR Summary
Help me add hafnium zirconium oxide in Silvaco
I am trying to simulate a Gate-All-Around FET in Silvaco TCAD for my thesis but I can't figure out how to add HZO (Hf0.5Zr0.5O2). I would really appreciate it if anyone could help me with the code for HZO or help me in any other way.
Thank you.
Here are some examples from Silvaco:
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
12K
