How to analyze heat transfer effects of viscoelastic fluids
In summary, the Oldroyd B fluid is a viscoelastic fluid model that does not accurately describe the behavior of real viscoelastic fluids.
Idrees Afridi
n the heat transfer analysis of boundary layer flow of viscoelastic fluids many researchers see the variation of temperature of fluid inside the boundary layer with Prandtl number, for which they use prandtl number 0.7, 2 , 3, 4 ..
This is what generally the researchers do..
Currently i am thinking that , such a analysis is wrong because the Prandtl number they use are of air and water and both fluids are not viscoelastic ..
Secondly , i need some examples of viscoelastic fluids with the correspoding values of Prandtl number.
Science news on Phys.org
Different fluids can have the same Prandtl number. It is only one of many properties used to characterize a fluid. It's not only air that is around 0.7, for example, but many gases.
But gasses are also not viscoelastic fluids then why they are using Prandtl number of gasses .
boneh3ad.. kindly give me some examples of viscoelastic fuids with Prandtl numbers..
I'm not much of a viscoelastic fluid expert, I'm afraid. I'm simply trying to point out that just because air has a Prandtl number of 0.7 doesn't mean that another fluid can't.
Before you start looking at complicated situations like boundary layer flow, I suggest you first look at heat transfer in steady state flow of viscoelastic fluid in a simple situation like a circular pipe. Assume that a certain location along the pipe, the pipe wall temperature suddenly changes from ##T_0## to ##T_1##. Before even considering the development of a temperature profile, do you know how to determine the velocity profile of a viscoelastic fluid in the pipe as a function of radial position.? If you can't work this problem, you will not be able to get a handle on what viscosity to use in calculating the Prantdl number, or what the Prantdl number should be.
Greetings:
the heat transfer analysis of viscoelastic fluid in a circular duct or curved circular duct has been investigated by many researchers and they are taking different Prandtl number without any justification. kindly check the link below and specially see the fig 3 in which the author mention that Pr=0.85
https://link.springer.com/article/10.1007/s00231-010-0641-3
why the researchers are taking Prandtl number of gases and water during the heat transfer analysis of viscoelastic fluids ?
The Oldroyd B fluid does not describe the behavior of any real viscoelastic fluids. It is a "viscoelastic fluid model" which exhibits certain qualitative features of real viscoelastic fluids, but can not describe the mechanical behavior of these fluids quantitatively. One of the qualitative features it does not describe correctly is the variation of the shear viscosity with shear rate. So, rather than the shear viscosity being a function of the radial velocity gradient, the Oldroyd B fluid predicts a constant value for the viscosity. In this case, it is possible to define a Prantdl number for the fluid based on a single unique viscosity parameter. The value this has in describing real-world heat transfer behavior of real viscoelastic fluid is, to say the least, highly questionable.
Related to How to analyze heat transfer effects of viscoelastic fluids
1. What is a viscoelastic fluid?
A viscoelastic fluid is a type of fluid that exhibits both viscous (resistance to flow) and elastic (ability to return to its original shape after deformation) behavior. Examples of viscoelastic fluids include polymer solutions, gels, and some types of biological fluids.
2. What is the significance of analyzing heat transfer effects of viscoelastic fluids?
Understanding the heat transfer effects of viscoelastic fluids is important in many industrial and scientific applications. This knowledge can help improve the efficiency of processes such as polymer processing, food processing, and oil extraction. It also has implications in fields such as biomechanics and biomedical engineering.
3. What factors affect heat transfer in viscoelastic fluids?
The heat transfer effects of viscoelastic fluids are influenced by several factors, including temperature, flow rate, fluid properties (such as viscosity and elasticity), and geometry of the system. Other external factors, such as pressure and surface properties, may also play a role.
4. How is heat transfer analysis of viscoelastic fluids typically performed?
There are various approaches to analyzing heat transfer in viscoelastic fluids, including experimental methods and computational simulations. In experimental methods, the fluid is typically subjected to controlled heating or cooling while its temperature and other relevant parameters are measured. Computational simulations use mathematical models and numerical methods to predict heat transfer behavior.
5. What are some challenges in analyzing heat transfer effects of viscoelastic fluids?
One major challenge in analyzing heat transfer in viscoelastic fluids is the complex nature of these fluids. Their behavior can be highly nonlinear and time-dependent, making it difficult to develop accurate mathematical models. Additionally, experimental measurements can be influenced by factors such as thermal and mechanical instabilities. Therefore, a multidisciplinary approach involving both experimental and computational methods is often necessary to fully understand heat transfer effects in viscoelastic fluids.
  • Thermodynamics
  • Materials and Chemical Engineering
  • Thermodynamics
  • Thermodynamics
  • Mechanical Engineering
