How to Analyze the FBD of a Toy Car on the Underside of a Dome?
  • Thread starter Thread starter bobbeh
    Weight
The discussion focuses on analyzing the free body diagram (FBD) of a toy car on the underside of a dome, emphasizing the forces acting on the car. Key forces include weight acting downward, the normal force directed toward the center of the dome, and the need for clarification on the frictional force's direction. Participants seek a labeled diagram to better visualize the scenario, questioning the clarity of the original problem statement regarding the car's motion and position. The conversation highlights the importance of precise definitions and diagrams in physics problems. Overall, a clear understanding of the forces involved is crucial for accurate analysis.
bobbeh
Draw the FBD including Kinetic Friction, Gravity, and Normal force
Fnet = mv^2/r
weight pointing down
Fn pointing down and to the left (to the center of the dome)
Fs pointing ..?? Should it not be off the page? Maybe up and off the page to oppose movement + gravity?
bobbeh said:
Homework Statement: Draw the FBD including Kinetic Friction, Gravity, and Normal force
Relevant Equations: Fnet = mv^2/r
Can you post a labeled diagram of your "vertically horizontal circle on the underside of a dorm" please?
Hi @bobbeh and welcome to PF.
The title:
"FBD of a toy car moving in a vertically horizontal circle on the underside of a dome"
is not clear.
Is the plane in which the circle lies horizontal or vertical (or something else)?
Is the car'speed constant?
Are the car's wheel rolling without slipping?
At what position is the car on the dome?
You need to provide the complete and exact original question, word-for-word (and as already noted by @renormalize, a diagram).
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
