Insights How to Apply Newton’s Second Law to Variable Mass Systems
Newton's second law, expressed as dP/dt = F_ext, can lead to confusion when applied to variable mass systems like rockets. In the example of a hovering rocket expelling combustion gases, a novice may incorrectly apply the equation, resulting in an impasse. The key condition for the rocket to maintain its position involves balancing the forces, specifically the thrust generated by the expelled gases against gravitational force. Understanding the nuances of variable mass systems is crucial for correctly applying Newton's second law. Proper application ensures accurate predictions of system behavior in dynamic scenarios.
kuruman
Education Advisor
Insights Author
Introduction
The applicability of Newton’s second law in the oft-quoted “general form”  $$\begin{align}\frac{d\mathbf{P}}{dt}=\mathbf{F}_{\text{ext}}\end{align}$$ was an issue in a recent thread (see post #4) in cases of systems with variable mass.  The following example illustrates the kind of confusion that could arise from the (mis)application of Equation (1):
A rocket is hovering in place above ground near the Earth’s surface. Assume that the combustion gases are expelled at constant rate ##\beta=dm/dt## with velocity ##w## relative to the rocket.  What condition must hold for the rocket to hover in place?
A novice might start with Equation (1) and go down the garden path only to reach a quick impasse as shown below.
Attempted solution
We start with the general form of Newton’s second law, Equation (1) $$\frac{dP}{dt}=M\frac{dV}{dt}+V\frac{dM}{dt}=-Mg$$ If...
Continue reading...
Likes PhDeezNutz, Lnewqban, Juanda and 3 others
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
This has been discussed many times on PF, and will likely come up again, so the video might come handy. Previous threads: https://www.physicsforums.com/threads/is-a-treadmill-incline-just-a-marketing-gimmick.937725/ https://www.physicsforums.com/threads/work-done-running-on-an-inclined-treadmill.927825/ https://www.physicsforums.com/threads/how-do-we-calculate-the-energy-we-used-to-do-something.1052162/
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
