How to Approximate Aerodynamic Coefficients? (Lift/Drag)
The discussion focuses on approximating lift and drag coefficients for hypersonic flow over blunt-body spacecraft during atmospheric reentry. The modified Newtonian fluid theory is identified as a suitable method for initial calculations, emphasizing the integration of the pressure coefficient over the non-shadowed region of the body. The original poster seeks guidance on applying this theory, as existing literature often omits detailed calculations or relies on proprietary software. They express difficulty in understanding the complex integrations involved and request examples or walkthroughs for their specific scenario. The conversation highlights the need for accessible resources or code to facilitate this analytical approach.
Dikuza
TL;DR Summary
Looking for an example to calculate lift and drag coefficients for hypersonic flow over a blunt-body
Hello, this is a very specific question so any help is much appreciated!
GOAL: I'm trying to get a first-pass analytical approximation for the lift and drag coefficients for hypersonic flow over a blunt-body capsule spacecraft (similar to NASA's Apollo or SpaceX's Dragon) during atmospheric reentry from LEO.
METHOD: I understand that modified Newtonian fluid theory is the best (most accurate for its simplicity) approach before considering any computationally-demanding and time-consuming CFD simulations. The basis of this theory is to integrate the pressure coefficient over the portion of the 3D body that is exposed to air flow ("non-shadowed region") using the equation Cp = Cp(max)*sin^2(theta).
ISSUE: I've done a fair amount of research, however, not having an extensive background in aerodynamics am struggling with how exactly this is applied. For a given vehicle shape, angle of attack, and mach number, how exactly is this done? Every paper I read (3 of which I've referenced below as examples) seem to skip over the actual calculations and reference some code that's been written or use an existing program like CBAERO that I don't have access to. I've also found a couple of the original documents from the 60's ( https://ntrs.nasa.gov/api/citations/19660012440/downloads/19660012440.pdf) that go over this but are pretty hard to follow. Has anyone done this before and could walk me through the process or point me to an example calculation for my scenario or code? If this approach is reportedly simpler than CFD and used as a means of quick design iteration, I would think it's not super difficult but I'm lost with the complex integrations and limits.
SOURCES:
https://engineering.purdue.edu/~mjgrant/48th-aiaa-aerospace-science.pdf: "After analytic relations are developed, they are output to a Matlab-based aerodynamics module."
https://www.intechopen.com/chapters/21789]https://www.intechopen.com/chapters/21789: "A computer program is written to compute the aerodynamic coefficients using the Newtonian sine-squared law" https://www.researchgate.net/publication/269802955_Application_of_Modified_Newton_Flow_Model_to_Earth_Reentry_Capsules: "A Fortran code has been written, making benefit of existing in-house library"
You might take a look in newer resources like "Hypersonic and High-Temperature Gas Dynamics" by John Anderson. Since it's a textbook, it's goal is to inform a reader how to do things like this.
You may also need to employ something like shock-expansion theory or the tangent-wedge/cone approximation depending on your shape (they're also fairly easy to implement and are in the above book).
Venus does not have a magnetosphere, so the Galactic Cosmic Rays (GCRs) environment shall be much worse than in a LEO environment. Looking to the std radiation models for Venus, the standard radiation-hard space level electronic component with tested immunity LET = 85 MeV-cm2/mg seems not enough, so, for example, a 1cm2 Si die will suffer considerable flux above this level during a long mission (10 years for example). So, the question is, usually we are not paying attention to latch-up...
Due to the constant never ending supply of "cool stuff" happening in Aerospace these days I'm creating this thread to consolidate posts every time something new comes along. Please feel free to add random information if its relevant. So to start things off here is the SpaceX Dragon launch coming up shortly, I'll be following up afterwards to see how it all goes. :smile: https://blogs.nasa.gov/spacex/
Thread 'SpaceX Starship development: 7th flight January 10'
Watch the progress live This is a fully stacked Starship (top) and Super Heavy (bottom). A couple of too-small-to-see cars near the bottom for scale, I also added a Saturn V and the Statue of Liberty for comparison. 120 meters tall, about 5000 tonnes when fully fueled. Twice the mass and over twice the thrust of Saturn V. The largest rocket ever built by mass, thrust, height, and payload capacity. N1 had the largest diameter.[/size] But its size is not the revolutionary part. It is designed...
