How to approximate IRR with simple formula for two loans of different terms
In summary, to approximate the IRR in this scenario, use the internal rate of return formula which takes into account both the size and duration of the loans.
Aidie1
I am trying to make a simple formula to approximate the IRR using the IRR of each loan, their respective term and loan size.
i.e.
loan one is $\$1,000,$ has a term of $10$ years and an IRR of $5\%$.
loan two is $\$100$ has a term of $1$ year and an IRR of $15\%$.
Using a simple weighted does not capture the difference of term - this would show an IRR of $5.91\%$, while the real IRR is $5.12\%$.
Any help is appreciated!
Mathematics news on Phys.org
The best way to approximate the IRR in this case is to use the internal rate of return formula, which takes into account both the size and duration of the loans. The formula is:
IRR = (PV1 + PV2 + ...) / (FV1 + FV2 + ...)
where PV stands for present value (the amount borrowed) and FV stands for future value (the amount repaid).
For example, for loan one:
PV1 = 1000
FV1 = 1000 * (1 + 0.05)^10
For loan two:
PV2 = 100
FV2 = 100 * (1 + 0.15)^1
Plugging these values into the formula gives us an estimate of the IRR of 5.12%.
FAQ: How to approximate IRR with simple formula for two loans of different terms
What is IRR and why is it important?
IRR stands for internal rate of return and it is a metric used to measure the profitability of an investment. It takes into account the time value of money and provides a single rate of return that can be used to compare different investment opportunities. It is important because it helps investors make informed decisions about which investments will yield the highest returns.
How does the simple formula for IRR work?
The simple formula for IRR is based on the concept of net present value (NPV). It calculates the discount rate at which the NPV of an investment is equal to zero. In simpler terms, it calculates the rate of return at which the initial investment will be paid back over the expected period of time.
Can the simple formula for IRR be used for two loans with different terms?
Yes, the simple formula for IRR can be used for two loans with different terms. It takes into account the cash flows from each loan and calculates the overall IRR for both loans combined. However, it is important to note that this formula may not provide an accurate result if the loans have significantly different terms or cash flow patterns.
What are the limitations of using the simple formula for IRR?
The simple formula for IRR has some limitations. It assumes that all cash flows are reinvested at the IRR rate, which may not be feasible in reality. It also assumes that cash flows are evenly distributed, which may not be the case for all investments. Additionally, it does not take into account any external factors such as inflation or taxes.
Are there any alternative methods for approximating IRR?
Yes, there are alternative methods for approximating IRR such as the modified internal rate of return (MIRR) and the discounted payback period. These methods may provide a more accurate result for investments with different terms or cash flow patterns. It is recommended to use multiple methods to compare and evaluate investment opportunities.
