How to break a water-detergent-oil emulsion
  • Thread starter nnovillo
  • Tags
    Break
In summary, the conversation discusses methods for breaking the emulsion of oil and detergent in the water used for cleaning iron furniture in order to prolong the water's usefulness and reduce contamination. The use of acid and chilling the solution are suggested as possible solutions, but the specific choice of surfactant system is important for successful recycling of the wash water.
nnovillo
Hi there,
We have a plant that manufactures iron furniture. The iron bars come from the provider plant with a cover of mineral oil. After cutting, folding and putting together the pieces, there is a rinse process with water and detergent to take out the oil cover. The remaining emulsion of water+detergent+oil is gathered into a recipient, and is reused for 15 days, when the solids are separated and the remaining liquids discarded.
I would like to know if there is a substance or a particular chemical that would allow us to break the emulsion physically separating the phases so we can remove the oil through a mecanical method, prolonging the useful life of the water we are using and obtaining a less contaminant residue.
Thanks!
If your detergent is an anionic one like a tall oil or a soap, adding acid will do the trick. Acid will protonate the anionic surfactant and eliminate it's ability to emulsify. The oil and the surfactant will separate out. You will need to add additional surfactant afterwards and adjust the pH to slightly basic. If your system uses a mixture of nonionic and anionic surfactants (VERY common) this might not work.
Sometimes you can chill the solution to just above freezing and the emulsion will become less stable and separate out with the surfactant. If that works, you will need to add more surfactant, of course.
In general, if you intend to recycle your wash water, a surfactant system must be carefully chosen to accomplish that. For example you might want to use a surfactant that is solid at room temperature but melts and works effectively at elevated temperatures. You would use this system at elevated temperature and chill the system to strip it back out.
Thanks for your reply Chemisttree, it was very helpful. Cheers, V.
Related to How to break a water-detergent-oil emulsion
1. How does a water-detergent-oil emulsion form?
A water-detergent-oil emulsion forms when small droplets of oil are dispersed in water and stabilized by a surfactant, such as detergent. The surfactant molecules surround the oil droplets, preventing them from clumping together and separating from the water.
2. What is the purpose of breaking a water-detergent-oil emulsion?
The purpose of breaking a water-detergent-oil emulsion is to separate the oil from the water. This is important in industries such as wastewater treatment and oil spill cleanup.
3. What are some methods to break a water-detergent-oil emulsion?
Some methods to break a water-detergent-oil emulsion include adding an acid or base to change the pH, adding salt to decrease the solubility of the surfactant, heating the mixture, and using a coagulant or flocculant to clump together the oil droplets.
4. How do you determine which method to use to break a water-detergent-oil emulsion?
The method used to break a water-detergent-oil emulsion depends on factors such as the type of emulsion, the type of surfactant used, and the desired outcome. Conducting small-scale tests and analyzing the properties of the emulsion can help determine the most effective method.
5. Can a water-detergent-oil emulsion be broken without using chemicals?
Yes, a water-detergent-oil emulsion can be broken without using chemicals by using physical methods such as centrifugation or filtration. However, these methods may not be as effective as using chemicals and may not be suitable for large-scale applications.
  • Earth Sciences
  • Biology and Medical
  • General Discussion
