elou
- 74
- 3
Poster has been reminded to please be more clear in defining the questions that they are asking
- TL;DR Summary
- This filter will not necessarily function exactly as a polarization filter, but will maybe help visualize some aspects of it. Also, to keep things simple, I will be using "filters" with a single slit.
For that we will need a laser pen and two square pieces of opaque, non reflecting material. In both these squares a slit will be cut, wide enough to let a beam of the laser pass through without any refraction effects.
First, after the laser has been turned on, one of the squares is placed in front of the beam, allowing free passage to the light.
If I am right, I did not try it, the spot on the screen will become smaller and smaller if the square is rotated to the left or to the the right until it is in a horizontal position. More light will come through if the square keeps being rotated until it has reached a vertical orientation again.
Then, the second square, placed in front of the first one, farther from the laser, is also slowly rotated left or right. Depending one the starting orientation, more or less light will pass, to the point that an orthogonal orientation of the second square relative to the first one will achieve an almost total extinguishing of the light passing through.
