How to build an energy-efficient house
  • Thread starter felipe douglas
  • Tags
    Build
In summary, the conversation discusses the thermal insulation properties of windows with two panes of glass separated by a layer of gas. The speakers consider various factors such as thermal conductivity and thickness, ultimately concluding that the gas layer is effective in reducing heat transfer. The thread has been marked as "solved" as the original poster has found a satisfactory solution to their question.
felipe douglas
The windows in your house will all have two panes of glass, separated by a thin layer of gas. It would be much simpler to just glue the two panes of glass together. Why does separating them with a layer of gas improve their thermal insulation?
a. Although the gas has the same thermal conductivity as glass, the additional thickness of the glass-gas-glass sandwich provides better insulation than the glass-glass sandwich would.
b. Gases have much smaller thermal conductivities than glass, so that thin layer of gas is much more effective insulation than the two layers of glass. The gas undergoes convection, but poorly because of the geometry.
c. Although the gas has a larger thermal conductivity than glass, it provides so much extra thickness to the window system that it is still worth including.
d. Heat cannot flow between gas and glass.
none
B? because insulators are used to minimize that transfer of heat energy.
[/B]
Hi filipe d.,
Welcome to Physics Forums!
You've marked the thread "Solved", does that mean you are no longer seeking help with your question?
Likes felipe douglas
gneill said:
Hi filipe d.,
yes, I was able to solve it!
Good for you!
I was just checking because occasionally new members will hit the "solved" button unintentionally, and as it's a sure way to ward off helpers from the thread it can be rather disconcerting for the new members.
Related to How to build an energy-efficient house
What is an energy-efficient house?
An energy-efficient house is a house that is designed and built to use energy more efficiently than a traditional house. This means that it requires less energy to heat, cool, and power, resulting in lower energy bills and reduced environmental impact.
Why is it important to build an energy-efficient house?
Building an energy-efficient house is important for several reasons. Firstly, it helps to reduce your carbon footprint and contribute to a more sustainable future for our planet. Secondly, it can save you a significant amount of money on energy bills in the long run. Lastly, an energy-efficient house can provide a more comfortable and healthier living environment for you and your family.
What are some key features of an energy-efficient house?
Some key features of an energy-efficient house include proper insulation, air sealing, energy-efficient windows, and high-efficiency heating and cooling systems. Additionally, using energy-efficient appliances and incorporating renewable energy sources such as solar panels can also greatly increase the energy efficiency of a house.
What are some tips for building an energy-efficient house?
Some tips for building an energy-efficient house include working with a professional architect or builder who specializes in energy-efficient design, choosing high-quality and energy-efficient materials, and properly sealing air leaks. It is also important to consider the orientation and landscaping of the house to maximize natural light and shade.
How much does it cost to build an energy-efficient house?
The cost of building an energy-efficient house can vary depending on several factors, such as the size and location of the house, the materials and features used, and the local building codes and regulations. However, in the long run, an energy-efficient house can save you money on energy bills and potentially increase the value of your property.
  • Thermodynamics
10K
