How to Calculate \(a+b+c\) for Equations Sharing Common Real Roots?
  • MHB
  • Thread starter anemone
In summary, the sum of coefficients for equations with common real roots refers to the total numerical values attached to the variables in an equation with real number roots. To calculate this sum, one must identify the common roots and add up their respective coefficients in each equation. This concept is important in understanding the relationship between equations, solving systems of equations, and analyzing mathematical models in fields such as engineering, finance, and physics. Examples of equations with common real roots include x + 2y = 6 and 3x - y = 1, and x^2 + 4x + 3 = 0 and 2x^2 + 8x + 6 = 0.
anemone
MHB
POTW Director
3,883
115
Here is this week's POTW:
The equations $x^2+ax+1=0$ and $x^2+bx+c=0$ have a common real root and the equations $x^2+x+a=0$ and $x^2+cx+b=0$ have a common real root. Find $a+b+c$.
Remember to read the https://mathhelpboards.com/showthread.php?772-Problem-of-the-Week-%28POTW%29-Procedure-and-Guidelines to find out how to https://mathhelpboards.com/forms.php?do=form&fid=2!
Congratulations to the following members for their correct solution!(Cool)
1. Greg
2. Opalg
Solution from Opalg:
The condition for the first equation to have a real root is $a^2-4\geqslant0$. The condition for the third equation to have a real root is $1-4a\geqslant0$. Those two conditions imply that $a\leqslant-2$.
Let $u$ be a common real root of the first two equations, and let $v$ be a common real root of the other two equations. Then $$(1)\qquad u^2 + au + 1 = 0,$$ $$(2)\qquad u^2 + bu + c = 0,$$ $$(3)\qquad v^2 + v + a = 0,$$ $$(4)\qquad v^2 + cv + b = 0.$$ Subtract (2) from (1) to get $(a-b)u + 1-c = 0$, so that $u = \dfrac{c-1}{a-b}$ (provided that $a-b\ne0$).
Now subtract (3) from (4) to get $(c-1)v + b-a = 0$, so that $v = \dfrac{a-b}{c-1}$ (provided that $c-1\ne0$). Thus $uv = 1$. But the product of the roots of (1) is $1$, and one of those roots is $u$. Therefore the other root must be $v$, so that $$(5)\qquad v^2 + av + 1 = 0.$$ Subtract (3) from (5) to get $(a-1)v = a-1$. But $a-1\ne0$ (because $a\leqslant-2$), and so $v=1$. It follows from (3) that $a=-2$, and from (4) that $b+c=-1$. Therefore $\boxed {a+b+c=-3}$.
It remains to consider what happens when $a-b=0$ or $c-1=0$. If $a=b$ then the first two equations have no common root unless $c=1$, in which case they are the same equation and it hardly makes sense for them to have a common root. Similarly, if $c=1$ then the other pair of equations have no common root unless $a=b$, in which case they are the same equation and again it hardly makes sense for them to have a common root. But if you do allow this situation to satisfy the conditions of the problem, then there is a solution whenever $a=b\leqslant-2$ and $c=1$. In that case, $a+b+c = 2a-1$, which needs not be equal to $-3$.
FAQ: How to Calculate \(a+b+c\) for Equations Sharing Common Real Roots?
What is the significance of the sum of coefficients for equations with common real roots?
The sum of coefficients for equations with common real roots is a useful tool for determining the relationship between the roots of a polynomial equation. It can help identify patterns and make predictions about the behavior of the equation.
How is the sum of coefficients calculated for equations with common real roots?
The sum of coefficients is calculated by adding together all of the numerical coefficients in the polynomial equation. For example, in the equation 3x^2 + 2x + 5, the sum of coefficients would be 3 + 2 + 5 = 10.
Can the sum of coefficients be negative?
Yes, the sum of coefficients can be negative if the polynomial equation has a mix of positive and negative coefficients. For example, in the equation 3x^2 - 2x + 5, the sum of coefficients would be 3 - 2 + 5 = 6.
How does the sum of coefficients change when the roots of an equation are complex numbers?
When the roots of an equation are complex numbers, the sum of coefficients will still be a real number. However, the sum may be a complex number if the equation has complex coefficients.
What can the sum of coefficients tell us about the nature of the roots of an equation?
The sum of coefficients can provide information about the number of real roots and the sum of the roots of a polynomial equation. It can also help determine if the roots are rational or irrational numbers.
