C/C++ How to Calculate a Student's Total Course Percentage in C++?
  • Thread starter Thread starter ineedhelpnow
    C++ Functions
The discussion focuses on completing a C++ program designed to calculate a student's total course percentage based on weighted scores from homework, midterm, and final exams. The program currently includes constants for maximum scores and weights but requires modifications to compute the midterm and final exam contributions. Participants suggest a step-by-step approach to enhance the program, starting with running it, then fixing the midterm calculation, and subsequently adding the final exam calculation. A proposed adjustment includes incorporating a quiz score, leading to a new weight distribution. Additionally, to improve clarity and maintainability, it's recommended to break down the calculations into separate variables for each component (homework, quiz, midterm, final) before combining them into the final course percentage. The conversation also addresses confusion regarding the initial question, with participants confirming the ability to run the program and encouraging progress through the outlined steps.
ineedhelpnow
The following incomplete program should compute a student's total course percentage based on scores on three items of different weights (%s):
20% Homeworks (out of 80 points)
30% Midterm exam (out of 40 points)
50% Final exam (out of 70 points)
Suggested (incremental) steps to finish the program:
1. First run it.
2. Next, complete the midterm exam calculation and run the program again. Use the constant variables where appropriate.
3. Then, complete the final exam calculation and run the program. Use the constant variables where appropriate.
4. Modify the program to include a quiz score out of 20 points. New weights: 10% homework, 15% quizzes, 30% midterm, 45% final. Run the program again.
5. To avoid having one large expression, introduce variables homeworkPart, quizPart, midtermPart, and finalPart. Compute each part first; each will be a number between 0 and 1. Then combine the parts using the weights into the course value. Run the program again.
Code:
#include <iostream>
using namespace std;
int main() {
   const double HOMEWORK_MAX = 80.0;
   const double MIDTERM_MAX  = 40.0;
   const double FINAL_MAX    = 70.0;
   const double HOMEWORK_WEIGHT = 0.20; // 20%
   const double MIDTERM_WEIGHT  = 0.30;
   const double FINAL_WEIGHT    = 0.50;
   double homeworkScore    = 0.0;
   double midtermScore     = 0.0;
   double finalScore       = 0.0;
   double coursePercentage = 0.0;
   cout << "Enter homework score:" << endl;
   cin  >> homeworkScore;
   cout << "Enter midterm exam score:" << endl;
   cin  >> midtermScore;
   cout << "Enter final exam score: " << endl;
   cin  >> finalScore;
   coursePercentage = ((homeworkScore / HOMEWORK_MAX) * HOMEWORK_WEIGHT)
                    + 0.0  // FIXME for midterm
                    + 0.0; // FIXME for final
   coursePercentage = coursePercentage * 100; // Convert fraction to %
   cout << endl << "Your course percentage (FIXME): ";
   cout << coursePercentage << endl;
   return 0;
i don't understand this question at all! please help!
Technology news on Phys.org
Were you able to run the program?
Yes
Ok, were you able to do the second step, and fix the midterm calculation? (Hint: It's the part in the code that has the first FIXME).
Thread 'Star maps using Blender'
Blender just recently dropped a new version, 4.5(with 5.0 on the horizon), and within it was a new feature for which I immediately thought of a use for. The new feature was a .csv importer for Geometry nodes. Geometry nodes are a method of modelling that uses a node tree to create 3D models which offers more flexibility than straight modeling does. The .csv importer node allows you to bring in a .csv file and use the data in it to control aspects of your model. So for example, if you...
I tried a web search "the loss of programming ", and found an article saying that all aspects of writing, developing, and testing software programs will one day all be handled through artificial intelligence. One must wonder then, who is responsible. WHO is responsible for any problems, bugs, deficiencies, or whatever malfunctions which the programs make their users endure? Things may work wrong however the "wrong" happens. AI needs to fix the problems for the users. Any way to...
