I How to calculate an unknown planet's orbital period?
The discovery of Neptune in 1846 resulted from mathematical calculations predicting its position based on observed perturbations in Uranus's orbit, which Newton's laws could not fully explain. Astronomers Urbain Jean-Joseph Le Verrier and John Couch Adams independently calculated the location of Neptune, leading to its observation by Johann Gottfried Galle. The process of calculating an unknown planet's orbital period involves measuring perturbations of known planets or using high-resolution telescopes for comparison against stellar backgrounds. The discovery of Pluto in 1930 further exemplified this method, as it was identified through its slow motion among background stars. Understanding these historical discoveries highlights the evolution of astronomical classification and the methods used to identify celestial bodies.
NODARman
In 1846 three astronomers and mathematicians discovered Neptune because Uranus wasn't quite moving as Newton's law of gravity explains. So they did calculations and point the telescope at a specific part of the sky. They discovered Neptune. What formulas did they use? How did they calculate this kind of hard problem?
Astronomy news on Phys.org
On the night of Sept. 23-24, 1846, astronomers discovered Neptune, the eighth planet orbiting around the Sun. The discovery was made based on mathematical calculations of its predicted position due to observed perturbations in the orbit of the planet Uranus. The discovery was made using a telescope since Neptune is too faint to be visible to the naked eye, owing to its great distance from the Sun. Astronomers soon discovered a moon orbiting Neptune, but it took more than a century to discover a second one. Our knowledge of distant Neptune greatly increased from the scientific observations made during Voyager 2’s flyby in 1989, including the discovery of five additional moons and confirmation of dark rings orbiting the planet.
https://www.nasa.gov/feature/175-years-ago-astronomers-discover-neptune-the-eighth-planet
With the 1781 discovery of Uranus, the number of known planets in the solar system grew to seven. As astronomers continued to observe the newly discovered planet, they noticed irregularities in its orbit that Newton’s law of universal gravitation could not fully explain. However, effects from the gravity of a more distant planet could explain these perturbances. By 1845, Uranus had completed nearly one full revolution around the Sun and astronomers Urbain Jean-Joseph Le Verrier in Paris and John Couch Adams in Cambridge, England, independently calculated the location of this postulated planet. Based on Le Verrier’s calculations, on the night of Sept. 23-24, 1846, astronomer Johann Gottfried Galle used the Fraunhofer telescope at the Berlin Observatory and made the first observations of the new planet, only 1 degree from its calculated position. In retrospect, following its formal discovery, it turned out that several astronomers, starting with Galileo Galilei in 1612, had observed Neptune too, but because of its slow motion relative to the background stars. did not recognize it as a planet.
I would expect that the perturbation calculations have been published.
For a modern example, https://aapt.scitation.org/doi/abs/10.1119/1.16307?journalCode=ajp
http://www.pas.rochester.edu/~blackman/ast104/perturbations.html
So, for an unknown planet, one would need a 'known' planet with which to measure a perturbation, or a high resolution telescope with which to compare the 'unknown' planet against the stellar background.
When Clyde Tombaugh discovered Pluto in 1930 using the 13-inch telescope at Lowell Observatory, it was only a point of light, detected among the background stars by its extremely slow motion. That motion translated to a 248-year orbital period, placing it at the edge of the solar system. It was a fantastic discovery, but Pluto at that time was not recognized as a new class of object, nor could it be, without knowing its mass. The mass, size and density of Pluto were for decades considered to be similar to the planet Mars.
https://www.nasa.gov/exploration/whyweexplore/Why_We_23.html
historically, the Pluto situation has occurred before in the solar system. Two centuries ago, in 1806, William Herschel’s discovery of the 7th planet, Uranus, was exactly 25 years in the past. But astronomers were rejoicing in the discovery of 3 new planets in the last three years, Ceres in 1801, Pallas in 1802 and Juno in 1804. And Vesta was about to be discovered in 1807. So in 1806, astronomers thought there were 11 planets. Astronomer James Hilton has shown how for almost 50 years the Nautical Almanacs listed 12 planets, including Vesta. Then, 39 years after those 4 new planets had been discovered, came a problem: in 1847 three new one were found, and by the end of 1851 there were 15. Only by the mid-19th century, ‘once their numbers grew too large to fit the existing scheme of classification,’ were ‘minor planets’ or ‘asteroids’ accepted as a class of their own. . . .
Likes collinsmark, NODARman, vanhees71 and 3 others
Is a homemade radio telescope realistic? There seems to be a confluence of multiple technologies that makes the situation better than when I was a wee lad: software-defined radio (SDR), the easy availability of satellite dishes, surveillance drives, and fast CPUs. Let's take a step back - it is trivial to see the sun in radio. An old analog TV, a set of "rabbit ears" antenna, and you're good to go. Point the antenna at the sun (i.e. the ears are perpendicular to it) and there is...
3I/ATLAS, also known as C/2025 N1 (ATLAS) and formerly designated as A11pl3Z, is an iinterstellar comet. It was discovered by the Asteroid Terrestrial-impact Last Alert System (ATLAS) station at Río Hurtado, Chile on 1 July 2025. Note: it was mentioned (as A11pl3Z) by DaveE in a new member's introductory thread. https://www.physicsforums.com/threads/brian-cox-lead-me-here.1081670/post-7274146 https://earthsky.org/space/new-interstellar-object-candidate-heading-toward-the-sun-a11pl3z/ One...
