How to calculate dA of a circle
  • Thread starter DDarthVader
  • Tags
    Circle
In summary, the problem involves calculating a fraction of the area of a circle with mass and radius R. The equation dm=M*dA/A=σ*dA is referenced, as well as dA=R*dR*dθ. The attempt at a solution involves dA=π*dR^2, which is incorrect. The correct solution is dA=r*dr*dθ, taking into account the angle. A clarification is made about the circle having mass, and the solution is confirmed.
DDarthVader
51
Hello! I need to calculate a little fraction (dA) of the area of a circle (mass m and radius R and area A) and I have no idea how to do this.
According to my textbook [itex]dm=\frac{M.dA}{A}=\sigma .dA[/itex] and [itex]dA=R.dR.d\theta[/itex].
Well, I tried to analyze the problem and my first thought was [itex]dA=\pi dR^2[/itex]. This is obviously wrong so I tried to think a little bit more and this is what I got [itex]dA=R.dR[/itex]... wrong again.
PS: is there a problem that I post here very often (create new topics)??
Thanks!
This is a calculus question.
Why does your circle have mass? Do you mean a disc?
You almost had it with [itex]dA = r \; dr[/itex], but you need to account for the angle. Think of it like this: start at a point [itex](r,\theta)[/itex]. From there, add a small radial distance [itex]dr[/itex] and a small angle [itex]d\theta[/itex]. Doing so should define a small rectangle. One side is just [itex]dr[/itex], but the other side, based on the change in angle, depends on how far away you are from the center of the circle: that side length is [itex]r \; d\theta[/itex].
The small differential area [itex]dA[/itex] is then just the product of the two side lengths of the (nearly) rectangular shape we have: [itex](dr)(r \; d\theta) = r \; dr \; d\theta[/itex].
Yes, sorry I was thinking about a disc. I think I got it now! Thank you for the answer and sorry for posting this question in the wrong forum.
FAQ: How to calculate dA of a circle
What is the formula for calculating the area (dA) of a circle?
The formula for calculating the area of a circle is dA = πr², where r is the radius of the circle and π is a mathematical constant approximately equal to 3.14.
How do I find the radius (r) of a circle if I only know the diameter (d)?
The radius of a circle can be found by dividing the diameter by 2, as r = d/2. Alternatively, if you only know the circumference (C) of the circle, you can use the formula r = C/2π.
What is the difference between diameter (d) and radius (r) of a circle?
The diameter of a circle is the distance across the circle passing through the center, while the radius is the distance from the center to the edge of the circle. The diameter is always twice the length of the radius.
How do I calculate the area (dA) of a circle if I only know the circumference (C)?
The area of a circle can be calculated using the formula dA = (C²/4π), where C is the circumference of the circle. Alternatively, you can first find the radius using the formula r = C/2π, and then use the formula dA = πr² to calculate the area.
Can I use the same formula to calculate the area of a semi-circle or quarter-circle?
No, the formula for calculating the area of a circle (dA = πr²) only applies to a full circle. To calculate the area of a semi-circle, you would use the formula dA = (πr²)/2, and for a quarter-circle, you would use the formula dA = (πr²)/4.
