How to calculate differential work done by a force in circular motion?
To calculate the differential work done by a force in circular motion, the correct expression for the differential displacement is d**r = d**θ × **r. The vector d**θ, which is defined as **n dθ, points along the rotation axis, and θ increases according to the right-hand rule. The discussion highlights the importance of the minus sign in the context of work done against the direction of force. Understanding these vector relationships is crucial for accurately determining work in circular motion scenarios. Proper application of these principles ensures correct calculations in physics problems involving circular dynamics.
zenterix
When dealing with differential vectors, I still struggle sometimes.
I'd like to calculate the differential of work done by a force acting on a particle mass undergoing circular motion
Let ##\vec{r}## be the vector from the center of the circular motion to the particle.
I believe I can write the equation below, but I am not sure if it is an equality or an approximation.
$$d\vec{r}=\vec{r} \times d\vec{\theta}$$
$$dW=\vec{F} \cdot d\vec{r}$$
$$=\vec{F} \cdot (\vec{r} \times d\vec{\theta})$$
$$=(\vec{F} \times \vec{r})\cdot d\vec{\theta}$$
$$=-(\vec{r} \times \vec{F})\cdot d\vec{\theta}$$
$$\implies dW=-\vec{\tau} \cdot d\vec{\theta}$$
My question is, is this correct, and if so, why the minus sign?
The only mistake is in the first line, which should be ##d\boldsymbol{r} = d\boldsymbol{\theta} \times \boldsymbol{r}##. The vector ##d\boldsymbol{\theta} = \hat{\boldsymbol{n}}d\theta## points along the rotation axis, and ##\theta## increases in the direction given by the right hand rule.
Likes zenterix and TSny
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
