- #36
John54321
- 38
I don't know that is why I guessed ? I'm not sure what the units would be this is why I'm using this forum for help.
John54321 said:I don't know that is why I guessed ? I'm not sure what the units would be this is why I'm using this forum for help.
John54321 said:So its got to be 184.375 (Knm) / 120 Mpa = 1.5365
Yes, that's what it measures, but the pascal is a derived unit, which means it is made up of a combination of other units. What are those units?John54321 said:I understand that this is why I have showed all of my workings for the first 4 parts of the question.
Mpa is a unit measure of pressure.
No. You keep describing things which Pascals are used to measure.John54321 said:Yes internal stress, young modulus and ulltimate tensile strength.
Yes, but how? What is the particular combination of these units which make up a Pascal but not something else?John54321 said:It's made up of N for Newton M for metre kg kilogram s second
That's better.John54321 said:Hi SteamKing
1 pascal = 1 m ^-1 kg s^-2
Sure you have, if you've studied algebra. Except instead of dividing units like N and m2, you were working with things like x and y. It's the same principle.John54321 said:10^3N-m / 10^6N/^2 = 0.001n-m 0r 0.000001n-m^2 after its sqt
Not sure this is correct not done nothing like this before
John54321 said:Morning SteamKing
Are you talking about seeing it like this 1/1000 n-m^2 ?
If not I am not sure what to do if this isn't correct.
I
John54321 said:So N-m being the denominator makes it be multiplied to N-M^2 end up as the numerator.
Sorry I don't get this ? maybe I need to sit down with someone and get this covered as I am running out of time.
Thanks for your help and patience.
It's not clear what you mean here.John54321 said:So what your saying is the units just change over ie n-m = m-n
John54321 said:Sorry I don't get this ? maybe I need to sit down with someone and get this covered as I am running out of time.
