How to calculate entropy of mixing in 2-d systems
In summary, the conversation on calculating the entropy of mixing in a two-dimensional system discussed the use of the equation ΔS=S1*ln((A1+A2)/A1) and its applicability in a physical model. The concept of temperature in a 2D system was also questioned, with the understanding that mixing can occur without a defined temperature. The possibility of using the holographic principle and the implications of having infinite systems in the calculation of entropy were also mentioned. Further clarification of the specific physical model and the equations involved was suggested for a more accurate understanding.
antonima
28
Hello physics forums,
I am writing a paper and I am wondering how to calculate the entropy of mixing in a two dimensional system. I am sure that entropy increases with mixing in a two dimensional system, but I do not know what equation to use. Would I just use the same equation as for 3-d systems?
In which case V (volume) should be replaced with A (area) .. and R would be removed altogether to become
Is this right? I would appreciate any help. I don't think it would be very scientific if I just said 'the entropy of the system surely increases when size increases'...
If A is a proxy for the number of particles in each system and if as homogenous 2D systems they are a non physical model (concepts of pressure and temperature do not apply), your equation seems to be correct, normalizing on A1.
Yes, particles. Or rather empty spaces which can be modeled as particles.
Hmm, well in order for there to be mixing there has to be some temperature, unless as you say the model is purely non physical. I suppose I am more interested in a physical model however. Do you know that equation perchance?
I'm not sure what you mean by a "physical model" in a 2D system which, to me, is a pure abstraction. One simply assumes complete random mixing in a plane given sufficient time. There need not be a "temperature" in such a model. If you want to model pressure and temperature parameters, you need to specify the problem in more detail. I'm not sure what your concept is. All I can think of, in terms of a 2D physical model, is a projection of mixing volumes on a plane.
Also, you left out [itex]n_1 R[/itex] in your own equation, so why are you now saying you're more interested in a physical model? In the purely abstract model, the entropy is simply a function of the number of particles and specifically the relative change in entropy, [itex] ln[(n_1 + n_2)/n_1] [/itex], which you chose to model by area A. Your equation gives sensible answers for the relative change in entropy as far as I can tell.
The way I understand it, mixing needs not occur, as long as it is possible in the future. When the 'partition' opens to let all the particles in A1 diffuse into A2, as soon as it opens then entropy is increased.. I think. It has something to do with the number of possible microstates divided by number of occupied microstates. At least that is what I read somewhere.
But then, this doesn't seem right since you can still extract energy from a system before it equalizes, so its entropy shouldn't be going up that soon. Something about total microstates definitely sounds right though.
Consider individual particles diffusing in between two planes, or particles diffusing on a surface.
Well, entropy of the system at A1 can be said to be any number above 0, due to the 3rd law of thermodynamics. If A2 is then infinity, then the system can be said to have infinite entropy when A1 and A2 mix since any number above 0 times infinity is infinity. So, any system mixed with an infinite system will have an infinite entropy. This is of course not a physical model since infinite systems do not exist. Still, it is part of the paper that I want to write - which may have implications in physical systems, but I am not sure.
It seems you are trying to invoke some aspects of the holographic principle which was developed for the entropy of black holes. According to this principle the increase in entropy at the surface as a result of infalling matter is [itex] dS = dM/T[/itex]. However for ordinary physical models involving ideal gases, the 2D model makes no sense.. Diffusion is not described by the equations you wrote. I would suggest you clarify your question before you re-post.
FAQ: How to calculate entropy of mixing in 2-d systems
What is entropy of mixing in 2-d systems?
Entropy of mixing in 2-d systems is a measure of disorder or randomness in a system. It quantifies the distribution of different components within a two-dimensional space.
How is entropy of mixing calculated in 2-d systems?
The entropy of mixing in 2-d systems can be calculated using the formula S = -kΣpi ln pi, where pi represents the fraction of the total area occupied by each component and k is the Boltzmann constant.
What is the significance of calculating entropy of mixing in 2-d systems?
Calculating entropy of mixing in 2-d systems can provide insight into the thermodynamic behavior of a system. It can also help in understanding the stability and phase transitions of the system.
Can entropy of mixing in 2-d systems be negative?
Yes, entropy of mixing in 2-d systems can be negative if there is a high degree of order or regularity in the distribution of components within the system.
How does temperature affect the entropy of mixing in 2-d systems?
Temperature plays a crucial role in the entropy of mixing in 2-d systems. As temperature increases, the disorder or randomness of the system also increases, resulting in a higher entropy of mixing.
