How to calculate equivalent inertia of an engine?
In summary: As crank angle increases, the inertia increases until it becomes significant at the top of the power stroke.
knight92
101
Hello, is there a formula or technique to calculate the equivalent inertia of an engine?
I think I will have to add up all the inertias of everything else rotating inside it but it has so many components like cams, followers, pulleys, water pump, crank, flywheel etc. What sort of effect will the reciprocating pistons have on the equivalent inertia?
Is there no way of estimating a reasonable equivalent inertia of an engine without getting into all the complication of finding out the inertia for each and every rotating part? it does not have to be very accurate.
It depends on what you ar planning to use this "equivalent inertia" for.
I need to model linear acceleration of a vehicle which involves the use of this equation:
Engine Torque - Clutch Torque = Equivalent inertia of engine*Angular acceleration of engine
felmon38 said:
Knight, this is an academic question, studied in any book about dynamic of machinery. You can find in this page, something about it
http://www.codecogs.com/library/engineering/theory_of_machines/inertia-forces-and-couples.php
The main idea is reducing all the mechanism in one of their componentes, and applying on it the energy equation
I am having a hard time understanding this. I am sorry if I am asking a dumb question but what is M and N, one of them seem to be the mass and the other M seems to be a moment ? I understand up till equation 4 but then equation 5 makes no sense to me.
Of course you don't ask for a dumb question but for a known question which is explained in the textbooks.
Where
is the force of the gas on the piston and is towards the crank.
It can be seen from the diagram that
is accompanied by a force in the connecting-rod of
, and the useful turning moment on the crankshaft during the power or outstroke is,
"Actually it is calculating equivalent torque which is given by force*distance where P/cos is force and OM is the perpendicular distance same is with P x ON"
So the equivalent inertia = Torque/Angular acceleration of flywheel right?
This whole problem is much easier if you formulate it using energy (such as the Lagrange method). In particular, the cylinder gas pressure is converted into crankshaft torque by means of a virtual work calculation with no trig involved. What I see here is the hard way to do the problem.
I hvnt looked into the Lagrange method yet but would it work for the whole vehicle inertia too?
I'm not sure what you mean when you ask, "would it work for the whole vehicle inertia too?" Until you learn about the Lagrange formulation, I think it is premature to attempt to answer such a question.
I am still trying to understand Lagrange method. What I have learned till now is
L = Kinetic Energy - Potential Energy
Then: d/dt (dL/dx(dot)) - dL/dx = 0
So I resolve for this and get an equation of motion but how do I relate this to inertia ? :oldconfused:
EDIT: I found K.E also equals to 0.5*Inertia*angular velocity. So would this angular velocity be the RPM of the engine?
The equivalent inertia depends upon what you define as your generalized coordinate. The engine rotation angle would be a good choice, in which case, engine rpm, expressed in rad/s, is the associated generalized velocity.
Be aware, however, that the generalized inertia, the I in your equation, is not a constant but rather varies with crank angle. Consider a one cylinder engine. When the piston is a TDC, a slight crank rotation does not involve significant piston motion. Thus, in this position, the inertia is determined by the crank and the connecting rod (mostly the crank); the same is true when the piston is at BDC. There are other points in between these two positions where piston motion is very significant for a small crank motion, and thus the generalized inertia is greater in these positions. With a multi-cylinder engine, there is some smoothing of the overall inertia, but it is still not a constant. Also, with a multi-cylinder engine, there is the possibility - a virtual certainty - that there will be torsional flexure between the crank throws, making this a many DOF problem.
Related to How to calculate equivalent inertia of an engine?
1. What is the equivalent inertia of an engine?
The equivalent inertia of an engine refers to the total amount of rotational inertia that an engine experiences when it is accelerating or decelerating. It is a measure of the engine's resistance to changes in its rotational speed.
2. How is the equivalent inertia of an engine calculated?
The equivalent inertia of an engine can be calculated by adding together the individual inertias of all the rotating components in the engine, such as the crankshaft, flywheel, and pulleys. This value can also be obtained from the engine manufacturer's specifications.
3. Why is it important to calculate the equivalent inertia of an engine?
Knowing the equivalent inertia of an engine is crucial for designing and selecting the appropriate size and type of motor or other power source that will be used to drive the engine. It also helps in understanding the overall performance and efficiency of the engine.
4. What factors can affect the equivalent inertia of an engine?
The equivalent inertia of an engine can be affected by various factors such as the weight, size, and distribution of the rotating components, the speed at which the engine is running, and the type of motor or power source used to drive the engine.
5. Are there any limitations to calculating the equivalent inertia of an engine?
Yes, there are certain limitations to calculating the equivalent inertia of an engine. This method assumes that all the rotating components have a constant angular velocity, and it does not take into account any external forces or torques acting on the engine, which can affect its inertia.
  • Mechanical Engineering
  • Classical Physics
10K
  • Mechanics
9K
12K
