How to calculate fatigue life in the creep realm?
In summary,}##The author is discussing how technology has advanced to the point where it is possible to detect micro fractures and conditions in real time. This allows for more conservative designs in pressure vessels, as long as the cost of materials increases. However, the author also notes that weight is not always an issue, and that sometimes risks must be taken in order to achieve a desired result.
wallymct
I am looking for some information on how to calculate fatigue life for materials at temperatures elevated into the creep realm. ASME Sec 8 Div 2 describes how to do this for carbon steel below 700F and stainless below 800F, but I am interested in temperatures > 1000F. I am performing an FEA and I have some high peak stresses (hot spots) that I do not how to deal with. Thanks.
What is the application?
Pressure Vessel but the peak stresses are not on the vessel boundary wall. The peak stresses are from discontinuities on stiffener plates.
I've never gotten into fatigue or creep on a boiler code application. Mine are generally gas turbine and jet engine applications. We have a whole group of analysis folks who specialize in that, but we mechanical design engineers must get into the ball park before we can produce a design for them to analyze. We use a massive amount of proprietary material test data that was gathered at great cost over the last several decades. I'd love to see someone more knowledgeable than me speak up concerning boiler code applications.
I see these very localized peek stresses "waved off" a lot (wouldn't be good practice for jet engines I imagine). Maybe the data to do the fatigue analysis is not generally available.
For decades, it was assumed that so long as we did not exceed yield at any KT location, we did not have a fatigue limit. But I've heard that some of the larger engine manufacturers have now spent enough time and money collecting enough data to know that is not entirely true; but I've never had access to this data.
But the fact of the matter is that every engine flying has places on critical components operating at or above yield. (Naturally, "above yield" is not entirely true because the metal will yield and redistribute the loads so as to not exceed yield.) So every engine flying will have a fatique life and a creep life, both of which can be seriously shortened depending on the actual load cycle the pilots apply to the engines. A single 50 degree F over temp event can cut these numbers by half or more. (Keep in mind that max turbine temps are typically several hundred degrees higher than the melting temperatures of the alloys they make the engine out of.) Required overhaul periods are planned around these limits, and actual cycles are tracked carefully. They also do periodic bore scope inspections to determine that no cracks exceed their critial acceptable length.
A really exciting new technology will monitor an engine full time the entire time the engine is operating. It knows the condition of every blade during every revolution of the engine, and can sound alarms when micro cracks so the engine can be shut down for an overhaul before it explodes. So far, these are only being put on industrial gas turbines because the fly boys don't like the extra weight. But my opinion is that it will soon find itself into the aviation market. So if the calculations say to overhaul the engine at 5000 hours, real time condition monitoring might let you get much more time between expensive overhauls.
It is amazing that there is technology that can detect micro fractures and conditions in real time. In the pressure vessel world it seems that we build with multiple levels of safety factors and end up with some very over designed systems (of course weight is no an issue for us). I would think that with the advancements of FEA tools, we would start to build with a little less conservatism, but that does not seem to be the trend. Maybe if the cost of materials increases this will change. I know that there are some methods for determining creep fatigue, but they are nonlinear and are strain based.
Adding weight to something that gets very hot and spins at 10,000 rpm is never a good thing. We try to avoid doing any more of that then we absolutely have to.
It doesn't take any significant extra weight to use a computer to "listen" to the vibration noise you are collecting anyway, if only to drive the cockpit vibration level indicators. The clever bit is figuring out what to listen for.
This technology is already flying on commercial aircraft in service.
Less conservatism ##\ne## more risk - provided you understand the sitation properly and you can control the relevant variables. That's one motivation for using advanced materials technology like turbine blades made from a single metallic crystal - everything you thought you knew about cracks propagating from grain boundaries doesn't apply when there are no grain boundaries any more.
Related to How to calculate fatigue life in the creep realm?
1. What is the creep realm in fatigue life calculations?
The creep realm in fatigue life calculations refers to the region in which a material deforms over time due to constant or fluctuating stresses at elevated temperatures. This phenomenon is known as creep and it occurs in materials such as metals, plastics, and composites.
2. How is the fatigue life in the creep realm different from conventional fatigue life?
The fatigue life in the creep realm differs from conventional fatigue life in that it takes into account the effect of elevated temperatures on material behavior. This means that the material's strength and stiffness decrease over time, leading to a shorter fatigue life compared to conventional fatigue life calculations.
3. What factors are involved in calculating fatigue life in the creep realm?
The factors involved in calculating fatigue life in the creep realm include the applied stress, temperature, time, and material properties such as creep behavior, stress-rupture strength, and creep rate. Additionally, the geometry and loading conditions of the component must also be considered.
4. How do you determine the creep behavior of a material?
The creep behavior of a material can be determined through laboratory testing, where the material is subjected to constant or fluctuating stresses at elevated temperatures over a period of time. The resulting data is then used to create a creep curve, which shows the relationship between stress, time, and strain rate.
5. What are some common methods for calculating fatigue life in the creep realm?
Some common methods for calculating fatigue life in the creep realm include the Larson-Miller parameter method, the Manson-Haferd method, and the Strain-Range partitioning method. These methods use mathematical equations and empirical data to estimate the fatigue life of a material under creep conditions.
  • Mechanical Engineering
17K
