How to calculate gating time from the rate of the random coincidence?
physicsclaus
Calculate gating time from the rate of the random coincidences.
I sincerely do not know what equation I should, that's why I want to have solution in this thread.
Hello everyone,
I am now doing experiment related to quantum erasure. After plotting the correlation measurement with and without blocking one of the polarization from the SPDC source (say, V polarization), I do not know how to work further on the gating time from the rate of the random coincidence, and even I do not know why I need to do required by the lab report. I hope some of the talents here can provide me with some insights to complete this part.
Please find the attached .csv file.
Channel 2 and channel 4 are the probe and the system. Photons pass through them, and when two photons come from each port and meet together then we will have coincidence rate.
Please comment and let me know if there is anything I need to clarify more.
Thanks a lot!
Calculating gating time from the rate of random coincidence involves understanding the concept of coincidence window and its relation to the rate of random coincidence. The coincidence window is the time interval during which the detection of two photons is considered a coincidence.
To calculate the gating time, you can use the formula: Gating time = 1/ (Rate of random coincidence * Coincidence window). The rate of random coincidence can be obtained by measuring the coincidence rate when the two channels are not correlated, i.e. when the polarization is not blocked.
In your experiment, channel 2 and channel 4 are the probe and the system, respectively. To obtain the rate of random coincidence, you can measure the coincidence rate when the polarization is not blocked in channel 2 and channel 4. This will give you the rate of random coincidence for your setup.
Once you have the rate of random coincidence, you can use the above formula to calculate the gating time. This gating time is important as it determines the time window in which you can detect correlated photons and measure their polarization.
I hope this helps in understanding how to calculate the gating time from the rate of random coincidence in your experiment. If you have any further questions or need more clarification, please do not hesitate to ask. Good luck with your experiment!
