- #36
Geordielad
- 28
- 9
$$\frac {2c\sin\beta} {e\cos\theta}$$
Yeah...that is sum of the torques = 0. Basically, that is a highly naive version of what we have done so far. Just forget about that at this point...It's not describing what you thought/think it is.Geordielad said:I will rewrite using \frac for the ##2c \sin\beta##section.
The gas spring manufacturer gives the formula ##F*E = S*J ## where F is force, E is the force moment arm, S is door weight, J is weight moment arm. Then ##F=\frac {S*J} {E}## with this I used the spreadsheet to calculate F for increments of 10 degrees. However I suspect I am missing something as the results for FH are much higher than I expected.
I'm not sure what you are talking about with the extending/compressing force. The force will just be a function of ##x##, it doesn't matter whether the hatch is opening or closing. It's always applying a force in the direction of the blue vector in post #8.Geordielad said:So if I understand what you are saying I should be using ##F=P*A## where F is cylinder force, P is pressure in cylinder, A is cross sectional area of piston, ##F_1## is extending force,##F_2## is compressing force, ##V_1## is cylinder volume extended, and ##V_2## is cylinder volume compressed.
Then ##F_1=P*A## and ##F_2=F_1*\frac{v1} {v2}##
ok.Geordielad said:What I was trying to say was that when the cylinder is compressed there is less volume therefore a higher pressure than when extended.
I mean all of those quantities ## \sin \beta, \cos \theta,## via trigonometric relations, identities, etc... are functions of ##x## and ##F_s## is a function of ##x## via some model like "The Ideal Gas Law".Geordielad said:Your suggestion to solve Fs analytically sound good but I don't understand ##\sin\beta=function (x),\cos\theta=g (x), F_s=q (x)## could you please explain how to find Fs.
Basically, A function of ##x## means there is a relationship that is determined by the variable ##x##, and a value of ##x## produces a single value for ##f(x)##Geordielad said:It is to help a friend who has even less math knowledge than me. I am 74 years young and my math is rusty to say the least. My apologies but I do not understand function of (x). and The ideal gas law is way over my head. Could I ask you to recap how to find Fs we got so far and then I lost the plot.
Don't let that worry you.Geordielad said:The ideal gas law is way over my head.
Do you have any manufacturer specs on the gas cylinder being used ( besides that equation you quoted earlier)? You want to be looking for a force vs displacement curve ( or set of curves ) for some specified initial conditions. If you can’t find that, I’ll give you a basic model. Since you don’t seem to be up to the challenge in the mathematical solution, you can just spot check some points using your CAD model. If your model is parametric, it won’t be much effort at all.Geordielad said:Is there an easier way for me to calculate Fs?
When I designed the gas strut lift system for the topper for my previous truck, the auto parts store made me a copy of the catalog page for gas struts. Almost all the important information was there - extended length, compressed length, and force. The one piece of information not there was the effect of temperature. The gas fill follows the idea gas law, where the pressure is proportional to the absolute temperature. The force is proportional to the pressure. I neglected to include the effect of temperature on the force, and the resulting design would not hold the top up at temperatures below 30 deg F. Other than that, it worked very well.Baluncore said:A gas strut is different. It has no piston or seal, just a perforated guide to keep it straight. As you push the rod in, the gas volume only changes by the volume of the rod, so the pressure changes much less than with a piston.
Maybe the words are used interchangeably, but the design of the one I had in mind is very much unlike the other in how they respond to displacement. The "strut" is the one that fits the application as a door opening assist.Geordielad said:As I understand it the terms are interchangeable.
You should be looking for ##\cos \beta## as a function of ##x##:Geordielad said:Erobz, I have figured out how to write the ##f (x) ##you mention in post 29 using the law of cosines and since I know all 3 sides. ##f(x)=\cos\left(\frac {x^2+a^2-b^2}{2xa}\right)## This gives me the angle designated ##sin beta## in post 29. for all the intermediate positions of the cylinder.
Instead of finding \cos\theta as a ##f(x)## could I use ##\cos angle BOA## as a ##f(x)##?
We are going to assume that it is a gas strut (in the application it makes the most sense), and that the force ##F_s ## is approximately constant in magnitude over the stroke. If you want to examine how it changes, and how that effects the force we can do that after as a refined model. The challenging part is getting the geometry worked out.Geordielad said:I am still working on ##F_s## as a ##f(x)##.
