Satvir
- 3
Hi all,
I'm going to make a roller shaft for a roller mixer. I will be using a aluminum tube of length 900mm placed horizontally and the two ends will be help in a bearing. An another pipe will be placed side by side to the first pipe with a bit of space in the middle and held the same way as the first. A 10Kg paint can (5L) that's filled 75% will be placed horizontally in between the two pipes. (See the attached image of the design).
Currently I'm looking at this pipe to buy http://uk.rs-online.com/web/p/tubing-struts/4355837/# . It's 1000mm but it will be reduced to 900mm.
Could anyone tell me a formula to calculate how much weight can the aluminum tube hold.
Many thanks
Many thanks
