How to calculate hydraulic disc brake size using actuation force?
In summary, the person is designing a hydraulic disc braking system for a go kart and has calculated the maximum braking force and torque of the vehicle. They want to calculate the brake size which should be able to stop the vehicle at 2.5 meter distance. They have calculated the maximum braking force and torque of the vehicle assuming the following: Area of piston = 0.00309677 m2, radius of rotor/disc = 0.07 m, distance from center of piston to center of wheel = 0.039, coefficient of friction onbetween pads and rotor = 0.61. They have also calculated the brake torque and force using pedal ratio and pedal force. They conclude that the brake torque
Hammad
hello,
How do i calculate brake size using force of actuation?
im designing a hydraulic disc braking system (only one rotor caliper located in the middle of drive shaft) for go kart and using simple pascal law, i have calculated the force of actuation of the hydraulic brake that is the force exerted by the piston on the brake pads. i have also calculated the maximum braking force and torque of the vehicle:
design of system:
now i want to calculate the brake size which should be able to stop the vehicle at 2.5 meter distance.
the kart specs are given below
The engine is 3.5 HP, 127 CC
total weight 170 Kg (loading condition)
stopping distance = 2.5 meters
Pedal ratio = 4:1
Pedal force = 300 N
The calculation i have done for maximum brake torque, force of actuation and brake torque using pedal ratio and pedal force is given below
assuming:
distance from centre of piston to centre of wheel = 0.039
coefficient of friction onbetween pads and rotor = 0.61Force on master cylinder = 300 * 4 = 1200 N
Fbp= Fd * pedal ratio
Fd = input force on the brake pedal
Fbp= output force from brake pedal
Fbp=300 * 4 = 1200
Pmc= Fbp / Amc
Pmc = pressure exerted by master cylinder
Amc =effective piston area of the master sylinder
Pmc = 1200/0.000387096
Pmc = 31 x 10 4
Pcal = Pmc
Pcal = pressure exerted by caliper
Fcal = Pcal * Acal
Acal = area of the one side of the caliper
Fcal = 387500* (0.00309677)
Fcal = 9600N
T = 2 μ F r
T = 2 * 0.61 * 9600 * (0.07-0.031)
Breaking Torque = 456.77 N.m
xxxxxxxxxxxxxxxxxxxxx
maximum braking Force and torque at stopping distance of 2.5 m:
assuimg:
wheel radius = 0.125 m
coefficient of friction btw tyre and road = 0.5
0 = u 2 + 2as
u = 50 km/hr
s = stopping distance = 2.5 meters
a = deceleration = 38.58 m/s2
F= ma =170 x 38.58= 6.5 KN
T = 2uFr
u = coefficient of friction = 0.61
r = radius of wheel = 0.25/2 m = 0.125 m
T = 2*0.5*6500*0.125
T = 812.5 N.m
How do i now calculate the size of the brakes?
I believe brake area is only important in avoiding brake fade caused by overheating. The greater the area the better the heat is spread and dissipated. Calculating the minimum area is complicated because it will depend on many variables... conductivity of the materials, total KE to be absorbed in stopping from maximum speed, heat build up from multiple stopping events in a short time, ambient temperature...
Likes Hammad
Difficult to see how to get a deceleration of 4g when the tyre coefficient of friction is less the one... especially when braking only 1/2 of the tyres, and with the weight transfer to the front during braking.
Likes Hammad, BvU and haruspex
Yes, I hadn't read through the calculations.
@Hammad , it does not matter how much braking torque you develop once you exceed mgμs of braking force. You will simply skid.
4g strikes me as unreasonable. A typical road car manages less than 1g on a dry road.
Likes Hammad
That might not be the place to start the calculations.
Normally, stopping distance would be an outcome of the braking.
Unless of course one wants to through out some sort of grabbing anchor, penetrate a stick into the ground, or drive through an energy absorbing substance such as snow, sand, mud, or traffic barrier, in which case the brakes aren't needed to stop.
Likes Hammad
so how do i achive the stopping distance of 2.5 meters?
any suggestions in the design?
2.5 meters is the stopping distance on the basis of which i have to determine the size of the brakes
what do you think i should do?
The question states, can you give me advice on where to start calculations so that i can design brakes to stop go kart at 2.5 meter distance?
Go kart has sprocket ratio 0.66:1 and transmission efficiency 80%. The engine model is 3.5HP 127cc, which has torque 7.5 Nm to drive
the Go-Kart with total weight 170 kgs (loading condition).
1) Calculate the maximum braking torque
2) calculate its braking torque if the pedal ratio is 4:1 and the pedal force is 300 N and choose brake material
3) design the brake system. Calculate the required brake size and disc brake size. The coefficient of friction for the selected brake material is applied based on above. Show by calculation that the proposed brake system is capable of stopping the Go-Kart within 2.5 metres stopping distance.
there's nothing there about speed at which the brakes are applied or coefficient of friction between tyre and road.
Likes Hammad
i have assumed as 50 km/hr and coefficient of friction btw tire and road as 0.9 under dry conditions.
Well, I see a 50 km/h. That's 14 m/s. And a friction coefficient that doesn't allow a lot of deceleration.
You'll need front braking too -- and even then: a friction coefficient of 1 allows deceleration at ##g## or ##\approx## 10 m/s2.
With ##{1\over 2} m v^2 = \mu mg d## it's easy to calculate that for ##\mu = 1## the stopping distance is at least 19 m.
2.5 m is simply unrealistic.
http://www.2pass.co.uk/stopping-distance.htm#.WhFvZ0riZEY
Likes Hammad
To stop in 2.5m you will need to change one or both of those assumptions. Pick one and calculate the other.
Edit: or include an anchor in the brake system.
Likes Hammad
yes i was thinking about that, the maximum speed i can use is 25 km/hr not more even with 1g deceleration
thanks for the detailed reply,
the only factor which i can directly put in calculations is the coefficient of friction of tire road speed of car,
but i have calculated the coefficient of friction of pad (by material selection) force of actuation, the size of rotor, the master cylinder bore, area of piston
from the link you posted and the formulas, it doesn't seem that the braking system design directly relate to the stopping distance.
is there any method to calculate the stopping distance using braking system dimensions and its material friction coefficients?
is there any way i can relate the design dimensions, properties to the deceleration value and then calculate the stopping distance?
thanks
thanks
The ability to attain a certain deceleration depends on both the grip on the road and the brakes. Each needs to cope with it independently.
You have dealt with the first by cutting the max allowed speed.
The calculation you did before for the brakes is basically valid, but I did not check the details.
You asked specifically about the area of the brakes. Standard school-level friction theory says the area of contact has no effect. As far as I am aware, the main consideration is overheating. A larger area spreads the released energy further.
Try calculating the heat released and estimating the temperature that woild result.
Likes Hammad
Hello,
i would just like to thank all the participants for their input, it helped to clarify the issues and confusion which i was facing and at the end, our lecturer did admit the fact that there were mistakes made in the assignment sheet.
thanks again for you spot on help
Related to How to calculate hydraulic disc brake size using actuation force?
1. What is actuation force and how does it affect hydraulic disc brake size?
Actuation force refers to the amount of force that is needed to engage the brake mechanism. This force is typically applied to the brake lever by the rider's hand. The amount of actuation force required will determine the size of the hydraulic disc brake needed. A larger actuation force will require a larger brake size to ensure efficient and safe braking.
2. How do I determine the correct actuation force for my hydraulic disc brakes?
The correct actuation force for your hydraulic disc brakes will depend on a few factors, including the weight of your bike and rider, the terrain you will be riding on, and your personal preferences. It is recommended to consult with a professional bike mechanic or refer to the manufacturer's guidelines for the recommended actuation force for your specific brake system.
3. Can I calculate the hydraulic disc brake size using the actuation force on my own?
While it is possible to calculate the hydraulic disc brake size using the actuation force, it is not recommended for beginners. This process requires a thorough understanding of the mechanics of hydraulic disc brakes and may require specialized tools. It is best to consult with a professional bike mechanic for accurate calculations.
4. Is the actuation force the only factor that determines the hydraulic disc brake size?
No, the actuation force is not the only factor that determines the hydraulic disc brake size. Other factors, such as the type of brake system, rotor size, and brake pad material, also play a role in determining the appropriate brake size. It is important to consider all of these factors when selecting hydraulic disc brakes for your bike.
5. Can I adjust the actuation force on my hydraulic disc brakes?
Yes, many hydraulic disc brakes come with adjustable actuation force settings. This allows riders to customize the amount of force needed to engage the brakes. However, it is important to note that changing the actuation force may also affect the braking power and performance of the brakes. It is recommended to consult with a professional mechanic before making any adjustments to the actuation force on your hydraulic disc brakes.
  • Mechanical Engineering
9K
  • General Engineering
9K
14K
13K
