I How to calculate incident light on surface with multiple orientations?
  • I
  • Thread starter Thread starter Jman99
To calculate the incident light intensity on a surface with multiple orientations, one must consider both the vertical and horizontal tilt angles. The intensity can be determined by multiplying the known intensity by the cosines of the angles of incidence. In this scenario, with a 45-degree vertical tilt and a 22-degree horizontal rotation, the projected area plays a crucial role in assessing light energy flux. The discussion emphasizes the importance of accurately accounting for these angles to achieve precise calculations. Understanding the relationship between angle and intensity is key to determining the effective light energy on the surface.
Jman99
Lets say you have a light source with a uniform beam of known intensity per meter square incident on a surface and the surface is tilted both vertically and horizontally.
The surface is on a platform and tilted directly up and the angle of incidence is 45 degrees while the platform is also rotated horizontally at 22 degrees (angle of incidence 22 degrees here?).
How to calculate the intensity? Is it just multiplying both the cosines of each angles by the intensity?
A good indication of the light energy flux would be the projected area - i.e. what you suggest.
Assume that this is a case where by sheer coincidence, two sources of coherent single-frequency EM wave pulses with equal duration are both fired in opposing directions, with both carrying the same frequency and amplitude and orientation. These two waves meet head-on while moving in opposing directions, and their phases are precisely offset by 180 degrees so that each trough of one wave meets with the crest of the other. This should be true for both the electric and magnetic components of...
