How to calculate magnetic induction just beyond the end of the magnet?
The discussion centers on calculating the magnetic induction just beyond the end of a bar magnet using the limit expression provided. There is confusion regarding the limit approaching infinity when substituting r with l. It is clarified that the expression was derived under the assumption that r is much greater than l, making it inappropriate for r approaching l. Instead, substituting r with l plus a small increment (epsilon) provides a more accurate approach. The key takeaway is to revisit the original equation for better insights into the behavior of the magnetic induction near the magnet's end.
Lotto
Calculate magnetic induction just beyond the end of a bar magnet on its axis
$$B=\frac{\mu}{4\pi}\cdot \frac{4rml}{{\left({r}^2-l^2\right)}^2},$$ where r → l.
Lotto said:
Homework Statement:: Calculate magnetic induction just beyond the end of a bar magnet on its axis
Relevant Equations:: $$B=\frac{\mu}{4\pi}\cdot \frac{4rml}{{\left({r}^2-l^2\right)}^2},$$ where r → l.
I know I should use a limit $$B=\lim_{r\to l}{\frac{\mu}{4\pi}\cdot \frac{4rml}{{\left({r}^2-l^2\right)}^2}},$$,but in Wolfram I get a weird solution. https://www.wolframalpha.com/input?i2d=true&i=Limit[Divide[4rl,Power[\(40)Power[r,2]-Power[l,2]\(41),2]],r->l]
What is the solution? It shouldn't be infinity.
According to the expression you quoted, it should be infinity. Note that you are asked to find the magnetic induction just beyond the end of the magnet, not at the end of the magnet. Also, I think your expression was derived in the limit ##r>>l## so you can't do much with it when ##r\approx l##. You need to go back to the original expression from which your equation was derived and see what you get when you substitute ##r=l+\epsilon## with ##\epsilon/l <<1##.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
