deeppurple247
- 2
Trying to calculate the net thrust of a rocket taking into account the force due to gravity. So I presume this is the calculated Thrust minus the force due to gravity.
Known data so far is that the rocket gets to escape velocity (11,200 m/s) after 5 minutes (300 secs). Acceleration for this is 11,200 / 300 = 37.3 m/s/s.
Next needed to calculate the mass loss rate of fuel. Equation given for this was was q = ma / v where q is the mass loss rate, m = final mass of rocket, a = acceleration and v = fuel exit.
m was given as 50,000 kg + 2000 Kg = 52,000 kg (without fuel)
v was calculated from equation earlier with sqrt((2 * (P2 - P1))/p), with given pressures and density. This came out as 2500 m/s
So...
q = (52,000 * 37) / 2500 = 770 kg/s
From this the Thrust (T) = qv = (770 * 2500) = 1,925,000 N (It was assumed the pressures were the same so T = qv)
Calculating the total mass of the rocket on launchpad needs the weight of the fuel which I presume is the mass loss rate (770 Kg/s) multiplied by the duration of fuel (300 secs) = 231,000 Kg
Therefore the force due to gravity is...
F = ma = (231,000 + 52,000) * 9.8 = 2,773,400 N.
This is more than the thrust calculated earlier which would give a negative net thrust which cannot be correct. Can anyone see where I've gone wrong please?
Regards
So...
Regards
