zenterix
- 750
- 84
- Homework Statement
- Consider the following simple titration problem.
We have 50mL of 0.10M solution of acetic acid (aq).
We use as titrant a 0.20M solution of NaOH(aq).
- Relevant Equations
- The equivalence point is reached after adding 25mL of titrant.
That is, all of the initial 0.005 mol of acetic acid (present in the 50mL analyte) is neutralized by the 0.005 mol of NaOH (present in 25mL of titrant).
0.005 mol of ##\mathrm{CH_3CO_2^-}## is generated and the concentration of this conjugate base is
$$\mathrm{[CH_3COO_2^-]_{init}=\frac{1}{15}M}$$
where "init" denotes simply the concentration right after neutralization before equilibrium is reached.
Suppose we want to find the pH at the equivalence point.
The way I know how to do it is the following.
Acetic acid has a dynamic equilibrium with water in aqueous solution given by
$$\mathrm{CH_3COOH(aq)+H_2O(l)\rightleftharpoons CH_3COO_2^-(aq)+H_3O^+(aq)}\tag{1}$$
We are given ##K_a=1.74\times 10^{-5}##.
The conjugate base of acetic acid is ##\mathrm{CH_3CO_2^-}## and it has a dynamic equilibrium with water in aqueous solution given by
$$\mathrm{CH_3CO_2^-(aq)+H_2O(l)\rightleftharpoons CH_3COOH(aq)+OH^-(aq)}\tag{2}$$
$$K_b=\frac{K_w}{K_a}=5.75\times 10^{-10}\tag{3}$$
Then
$$\mathrm{K_b=\frac{[CH_3COOH][OH^-]}{[CH_3CO_2^-]}=\frac{x^2}{\frac{1}{15}-x}}$$
$$\implies x=\mathrm{[OH^-]}=6.19\times 10^{-6}$$
and we get a pH of 8.79, which makes sense since ##\mathrm{CH_3CO_2^-}## is a weak base in water and at the equivalence point we have a solution of this weak base.
My question is the following.
Can we obtain the same result using (1) and ##K_a##?
I am not sure how to do it.
In (2) we are saying that acetate does proton transfer with a water molecule generating acetic acid and hydroxide and we work with the corresponding equilibrium and equilibrium constant ##K_b##.
In (1) we are saying that acetic acid does proton transfer with a water molecule generating acetate and hydronium. There is an equilibrium and an equilibrium constant ##K_a## that is related to ##K_b##.
So, at the equivalence point, we start with 1/15 M of acetate, no acetic acid, and some very small amount of hydronium. The exact amount of hydronium can be computed by computing the pH of the initial solution with just acetic acid in equilibrium
$$\mathrm{1.74\times 10^{-5}=\frac{x^2}{0.10-x}\implies x=[H_3O^+]=1.3104\times 10^{-3}M}$$
and then computing the concentration after adding titrant to reach the equivalence point
$$\mathrm{\frac{1.3104\times 10^{-3}\cdot 0.050}{0.075}=0.0008736M}$$
But what to do next?
Then
