BiGyElLoWhAt
- 131
I'm doing a project on the redshift from a star system (I chose a binomial system because why not). I might be going a little overboard using topology to calculate redshift, but whatever. First off, can I just treat a binomial system as the superposition of 2 sources which result in the schwartzchild metric? By that I mean one star isolated from the other would have the sc metric, as would the other, and the resulting system would have a similar metric, but there would be a path along 2 metrics to consider. So the topology from metric 1 + the metric from topology 2 along a path. I think this would work, but I'm not sure. I'm also not 100% on how to put this into a computer program.
Schwartzchild metric.
##c^2d\tau^2= (1-\frac{r_s}{r})c^2dt^2 - (1-\frac{r_s}{r})^{-1}dr^2 -r^2(d\theta^2 + sin(\theta)d\phi^2)##
I mean... I'm not sure what to put here.
First off, the left hand side is the proper time (of a photon), a differential element of which should be zero, I believe. Are the differentials on the RHS for an observer? So dr, dt, etc would be traced from the surface of emission to my observer? I'm tempted to assume that dt is a function of dr, or vice versa, along with theta and phi (zero, since I'm working in 2 spatial dimensions).
So correct me, please, but what I think I'm working with is something to the effect of:
##0 = (1-\frac{r_s}{r})c^2(dt(r,\theta))^2 - (1-\frac{r_s}{r})^{-1}dr^2 -r^2d\theta^2##
Or is this not useful (or even correct)?
Would it be better to solve for dt?
The reason I want to do it this way, is the only equation I've been able to find for redshift is either the Newtonian limit, or the limit as r-> inf. I want the redshift over a finite spatial distance.
I'm probably missing some things. So feel free to point them out.
**Edit
Ok, I suppose the RHS wouldn't be the coordinates for the observer in that manner, explicitly. However, the coordinates of the observer would be the end point of the path.
