Shaun_W
- 320
- 10
I'm involved in a project and I have to design a device that will "cap" the flow of water coming out of a pipe, which is located underwater. This device has to be transported down by an ROV that we have already made, so that's not a problem.
The device I am creating involves a solenoid being inserted inside the pipe. It is then actuated, pushing the arm out against the wall of the pipe. There will be a buffer material - probably rubber, unless anyone has any better suggestions - which will cause friction between the arm of the solenoid and the wall of the pipe. The solenoid will be keeping the cap in place, which will be stopping the water flow.
Below is the pretty diagram that I drew on Paint:
http://img31.imageshack.us/img31/3723/pipewithsolenoid.jpg
Uploaded with ImageShack.us
As you can see the water will be pushing upwards with a force of WF, the solenoid arm will be pushing against the inside of the pipe with a force of F, there will be a buffer material with area A on both the end of the solenoid and at the end of the arm.
What I need to know is how to calculate the required friction force between the buffer material and the wall of the pipe, if the water force, WF, pushing upwards is 1000N and the diameter of the pipe is 4.1cm?
Thanks!
Thanks!
