MHB How to Calculate the Area Between Two Vectors in R^n?
  • Thread starter Thread starter poissonspot
    Area Vectors
poissonspot
Hi, I wondered whether a well known expression is known that computes the area between two vectors in R^n. By area between two vectors, I mean the area that would be computed by considering the subspace spanned by the two, projecting the entire space to a "parallel plane" and then finally given by the magnitude of the cross product of the image of the vectors under this projection. Thank you,
In other words, given vectors $a,b$ in $\mathbb{R}^n$, you want the area $A$ of the parallelogram with vertices at the origin, $a$, $b$ and $a+b.$ If the angle between the vectors is $\theta$, this can be expressed in terms of the dot product by $$A = |a||b|\sin\theta = \sqrt{|a|^2|b|^2(1-\cos^2\theta)} = \sqrt{|a|^2|b|^2 - (a\cdot b)^2}.$$
Thread 'Derivation of equations of stress tensor transformation'
Hello ! I derived equations of stress tensor 2D transformation. Some details: I have plane ABCD in two cases (see top on the pic) and I know tensor components for case 1 only. Only plane ABCD rotate in two cases (top of the picture) but not coordinate system. Coordinate system rotates only on the bottom of picture. I want to obtain expression that connects tensor for case 1 and tensor for case 2. My attempt: Are these equations correct? Is there more easier expression for stress tensor...
