How to calculate the band structure?
In summary, Lucy says that the number of points you use to calculate the band structure is a somewhat-arbitrarily assigned number, and that you would choose the number of points in proportion to the distance between the special coordinates that line segment connects.
Miranda_Lucy
Hi, all,
I want to calculate the band structure and there is example such like that:
BandLinesScale pi/a
%block BandLines # These are comments
1 0.000 0.000 0.000 \Gamma # Begin at Gamma
50 2.000 0.000 0.000 X # 25 points from Gamma to X
20 2.000 1.000 0.000 W # 10 points from X to W
30 1.000 1.000 1.000 L # 15 points from W to L
40 0.000 0.000 0.000 \Gamma # 20 points from L to Gamma
50 1.500 1.500 0.000 K # 25 points from Gamma to K
20 1.000 1.000 1.000 L # 15 points from W to L
30 2.000 0.500 0.500 W # 10 points from L to U
20 2.000 0.000 0.000 X # 25 points from U to X
Is there anyone can tell me how to define the number of the points and the coordinate of these points? thank you very much
Yours,
Lucy
The coordinates are points at the edge of the first Brillouin zone (except for gamma). If you imagine the 3D Brillouin zone, the points will be either vertices, centers of edges, or centers of faces. You generally have to look those up, as the notation and location of these points depends on your Brillouin zone.
For the number of points, it's a somewhat-arbitrarily assigned number. Usually you would choose the number of points in proportion to the distance between the special coordinates that line segment connects.
Hi,thank you very much. but I am still confused about the coordinate.
Can you give me an example? Someone said we should choose the symmetry points---special K point. How can we find the highly symmetry point.
Thank you very much
Yours,
Lucy
Well, I already said that high symmetry points are either vertices, centers of edges, or centers of faces of the Brillouin zone. If you want the names (X, K, M, etc.) you have to look them up for your particular Brillouin zone, and for some BZ's they will depend on things like the c/a ratio.
Look at the Brillouin zone for fcc here:
http://en.wikipedia.org/wiki/Brillouin_zone
X is a center of a square face, K and U are centers of an edges, W is a vertex and L is the center of a hexagonal face.
Lucy,
Try to google “table for high symmetry points for brillouin zone” and you should get several web sites that contains table for the coordinates of the high symmetry points for several types of crystals.
Rany
Related to How to calculate the band structure?
1. How do I calculate the band structure of a material?
To calculate the band structure of a material, you will need to use quantum mechanics and the Schrödinger equation. This involves solving for the wave function of the electrons in the material and determining the energy levels within the material's crystal lattice. The resulting energy levels will form the band structure of the material.
2. What factors affect the band structure of a material?
The band structure of a material is affected by various factors such as the type of atoms in the material, their arrangement in the crystal lattice, and the strength of the bonds between them. The shape and size of the crystal also play a role in determining the band structure.
3. Can band structure calculations predict a material's properties?
Yes, band structure calculations can provide valuable information about a material's properties such as its electrical conductivity, optical properties, and magnetic properties. By analyzing the band structure, scientists can determine the energy levels available for electrons to move and interact, which can help predict the material's behavior.
4. What techniques can be used to calculate the band structure?
The most commonly used techniques for calculating the band structure are the Tight Binding method, the Density Functional Theory (DFT), and the Plane Wave Basis set method. Each of these techniques has its advantages and limitations, and the choice of method depends on the material and the level of accuracy required.
5. How do I interpret the band structure of a material?
The band structure is typically represented as a graph with energy on the y-axis and momentum on the x-axis. The bands in the graph represent the energy levels available for electrons to occupy. A large band gap indicates that the material is an insulator, while a small band gap or overlapping bands indicate that the material is a conductor. The shape and dispersion of the bands can also provide information about the material's properties.
  • Mechanical Engineering
  • Atomic and Condensed Matter
9K
