RAHMAN
- 1
cable size calculation
between QRM and 11kv to 400v transformer (1500 kva)
Babadag said:If you know the circuit breaker short-circuit rated current then you may use the NEC Table 240.92(B) Tap Conductor Short-Circuit Current Ratings.[for copper conductor]:
The factors that should be considered when calculating the cable size between QRM and transformer include the voltage and current rating of the transformer, the distance between the QRM and transformer, the type of cable being used, and the expected load on the transformer.
To determine the appropriate cable size, you will need to use a cable sizing calculator or consult the manufacturer's specifications for the transformer. You will need to input the voltage and current ratings, the distance between the QRM and transformer, and the expected load to get an accurate cable size recommendation.
No, it is not recommended to use a smaller cable size than what is recommended. Using a smaller cable size can lead to overheating and potential damage to the equipment. It is important to follow the recommended cable size to ensure proper functioning and safety.
Using a larger cable size than what is recommended will not necessarily cause any harm, but it can be a waste of resources and may lead to unnecessary costs. It is best to follow the recommended cable size for optimal performance and cost-effectiveness.
It is not recommended to use the same cable size for both connections. The cable size for the QRM to transformer connection is typically smaller than the cable size for the transformer to load connection. This is because the QRM is usually located closer to the transformer, and the voltage drop is less significant over a shorter distance.
