How to calculate the derivative in (0, ∞)?
In summary, the function f: R → R is defined as f(x) = (tan x) / (1 + ³√x) for x ≥ 0, sin x for (-π/2) ≤ x < 0, and x + (π/2) for x < -π/2. For the interval (0,∞), the function is defined as f(x) = (tan x) / (1 + ³√x) for x ≥ 0. The derivative of this function is f'(x) = (3x²/³) (1 + x¹/³) sec²x - tan x / (1 + ∛x)² or f'(
SixBooks
The function f: R → R is: f(x) =
(tan x) / (1 + ³√x) ; for x ≥ 0,
sin x ; for (-π/2) ≤ x < 0,
x + (π/2) ; for x < -π/2
_
For the interval (0,∞), we are interested in f such that
f(x) = (tan x) / (1 + ³√x) ; for x ≥ 0
f(x) = tan x / (1 + x¹ʹ³)
           (1 + x¹ʹ³)•sec²x − tan x  •  (⅓ x ⁻²ʹ³)
f'(x) = ———————————————            ← by the quotient rule
                            (1 + x¹ʹ³)²
           (1 + ∛x) sec²x   −   (tan x  /  (3 ∛(x²))
f'(x) = ———————————————                  ← ANSWER
                            (1 + ∛x)²
                              OR
           3x²ʹ³ (1 + x¹ʹ³)•sec²x − tan x
f'(x) = —————————————                  ← ANSWER
                     3x²ʹ³ (1 + ∛x)²
>> From here I can't go any further...
Any help is more than welcome!
What are you trying to do? The answer is clumsy, but it looks correct.
_
In the last line above, what you wrote doesn't make sense. You have x¹ʹ³. I can't tell what the symbol is between 1 and 3. Is that supposed to be x1/3?
BTW, homework- or coursework-type problems should be posted in the Homework & Coursework sections, not in the technical math sections. I have moved this thread.
Related to How to calculate the derivative in (0, ∞)?
1. What is the definition of a derivative in (0, ∞)?
The derivative in (0, ∞) is defined as the limit of the slope of a function at a specific point in the interval, as the distance between two points on the function approaches zero.
2. How do I calculate the derivative of a function in (0, ∞)?
To calculate the derivative in (0, ∞), you can use the limit definition of the derivative or use the rules of differentiation, such as the power rule or product rule.
3. What is the importance of calculating the derivative in (0, ∞)?
Calculating the derivative in (0, ∞) allows us to determine the rate of change of a function at a specific point, which is crucial in many scientific and mathematical applications, such as optimization and modeling.
4. Are there any special cases when calculating the derivative in (0, ∞)?
Yes, there are special cases such as when the function has a discontinuity or a vertical tangent at a point in the interval. In these cases, the derivative may not exist or may need to be calculated using different techniques.
5. Can I use a calculator to calculate the derivative in (0, ∞)?
Yes, there are many online calculators and software programs that can calculate the derivative in (0, ∞) for you. However, it is important to understand the underlying principles and techniques to ensure accuracy and fully comprehend the concept.
