How to calculate the drag force of a Bussard ramjet?
In summary, the conversation discusses the potential applications of nuclear fusion, specifically in regards to a Bussard ramjet. The ramjet would use a large electromagnetic field to collect hydrogen atoms and compress them until they fuse, generating energy for the spaceship. However, calculations show that the drag force from collecting and accelerating the hydrogen atoms may make this application unfeasible. The conversation also delves into the equations and values needed to calculate the thrust and drag for a Bussard ramjet at different speeds, including mass, electromagnetic field radius, hydrogen density, fusion temperature, cross section, and energy output.
Nivek Writer
Hello everyone,
I am making a paper on the possible applications for nuclear fusion.
One of these possible applications is a Bussard ramjet. I'm trying to calculate if Bussard ramjets
are feasible, based on their thrust and the drag they experience. A Bussard ramjet would
use a very big electromagnetic field to collect hydrogen from its surroundings.
These hydrogen atoms are compressed by the electromagnetic field until the atoms fuse.
The energy of the nuclear fusion can then be used to accelerate the spaceship.
I have a about Bussard ramjets. First, I know that Bussard ramjets probably
won't work due to the drag they experience from collecting hydrogen and accelerating the hydrogen atoms
to the speed of the spaceship. I calculated with the equation a = π r2 ρ η c2 / M from http://www.dangermouse.net/gurps/science/ramjet.html that a spaceship with a mass of 9.8 * 106 kg and a electromagnetic field radius of 3000 km would have an acceleration of 1g.
For η I used the factor 0.00753 (0.753%) of hydrogen fusion and for ρ I used the value 5 * 10-21 kg/m3 based on 0.3 hydrogen atoms per cm3 in outer space.
Using F = m*a, I calculated that this spaceship would have a thrust of 9.6 * 107 N. Furthermore, I calculated (with an equation from that website) that the minimum speed for nuclear fusion to be possible has to be 0.06c. Now, I want to calculate the drag force of the hydrogen atoms on the spaceship when it has a speed of 0.06c. My question is, how do you calculate the drag force of hydrogen atoms on a Bussard ramjet when you know all these other values?
P.S.: I calculated the mass for the spaceship (9.8 * 106 kg) with the equations from dangermouse and a picture from http://orbitalvector.com/Interstellar%20Flight/Bussard%20Ramjet/Bussard%20Ramjet.htm which states that a ramjet with a scoop radius of 3000 km and an acceleration of 1g would have to go at least 0.06c in order for the fusion reaction to function.
That's an awfully broad magnetic field. Compare to the radii of Earth and Mars.
The fusion efficiency has no basis. What fusion reaction would one propose? It certainly can't be p+p, since the cross-section is rather low.
Hello Astronuc,
Thanks for responding. I also thought that the equation I used seemed strange, since it didn't incorporate the cross section of the fusion reaction.
Let's say I have these values:
- A spaceship with a mass of 1000 tons
- An electromagnetic field with a radius of 200 km
- A hydrogen density in space of 5 * 10-21 kg/m3
- The nuclear fusion in the spaceship takes place at a temperature of 100 million Kelvin (8.62 keV)
- The cross section of p+p fusion at this temperature is 3.5438*10-41 cm3/s = 3.5438*10-47 m3/s using page 20 of http://www.fisicanucleare.it/documents/0-19-856264-0.pdf
- P-p fusion generates 5.91 * 1014 J per kg of fused hydrogen atoms
How do I use these values to calculate the thrust and the drag of this Bussard ramjet? Which equations do I use?
I know the ramjet I described above wouldn't work, because of the extemely low cross section of the p-p fusion, but I would
like to show this by calculating the thrust and drag of the ramjet. How do I use these values to calculate the thrust and the drag of this Bussard ramjet at different speeds? Have I forgotten any values? I Which equations do I use?
Related to How to calculate the drag force of a Bussard ramjet?
1. How does the speed of the Bussard ramjet affect the calculation of drag force?
The speed of the Bussard ramjet does not directly affect the calculation of drag force. However, the faster the ramjet is traveling, the larger the magnitude of the drag force will be.
2. What is the formula for calculating the drag force of a Bussard ramjet?
The formula for calculating the drag force of a Bussard ramjet is Fd = ½ ρ v² A Cd, where Fd is the drag force, ρ is the density of the surrounding medium, v is the velocity of the ramjet, A is the cross-sectional area of the ramjet, and Cd is the drag coefficient.
3. How does the cross-sectional area of the Bussard ramjet impact the drag force?
The cross-sectional area of the Bussard ramjet directly affects the drag force. A larger cross-sectional area means there is more surface area for the surrounding medium to exert a force on, resulting in a larger drag force.
4. What is the significance of the drag coefficient in the calculation of drag force?
The drag coefficient takes into account the shape and geometry of the Bussard ramjet and how it interacts with the surrounding medium. A higher drag coefficient means there is more resistance to motion, resulting in a larger drag force.
5. Can the drag force of a Bussard ramjet be reduced or eliminated?
The drag force of a Bussard ramjet cannot be completely eliminated, but it can be reduced through various design techniques such as streamlining the shape, reducing the cross-sectional area, and using materials with low drag coefficients. Additionally, the ramjet can be operated at higher speeds to reduce the effect of drag force.
12K
