mercuryman
- 6
given 3 vectors : a=(1,3,4) b=(2,5,3) c=(1,0,0)
mercuryman said:given 3 vectors : a=(1,3,4) b=(2,5,3) c=(1,0,0)
mercuryman said:Hi
I've marked the unknown vertex d=(x,y,z)
and tried to calculate its values by the fact that AB=CD and AC=BD and I'm missing something.. can u help?
To find the fourth vertex of a parallelogram, you will need to use the properties of a parallelogram. One of these properties is that opposite sides are equal in length. So if you know the lengths of two adjacent sides, you can use this property to calculate the length of the missing side. Once you have the length of the missing side, you can find the coordinates of the fourth vertex by using the coordinates of the other three vertices.
Yes, you can use the Pythagorean Theorem to find the fourth vertex of a parallelogram. This theorem states that in a right triangle, the square of the length of the hypotenuse is equal to the sum of the squares of the other two sides. In the case of a parallelogram, you can use this theorem to find the length of the missing side, which will help you determine the coordinates of the fourth vertex.
No, you do not need to know the angles of the parallelogram to find the fourth vertex. While knowing the angles can help you visualize the shape, it is not necessary for finding the coordinates of the fourth vertex. Using the properties of a parallelogram, such as equal opposite sides and parallel lines, is sufficient for calculating the missing coordinates.
There is no specific formula for finding the fourth vertex of a parallelogram. However, there are a few different approaches you can take depending on the information you have. If you know the coordinates of the other three vertices, you can use the distance formula or the midpoint formula to find the coordinates of the fourth vertex. If you only know the lengths of the sides, you can use the properties of a parallelogram to calculate the missing coordinates.
Yes, you can use trigonometry to find the fourth vertex of a parallelogram. If you know the lengths of two adjacent sides and the included angle, you can use the trigonometric ratios (sine, cosine, and tangent) to find the length of the missing side. From there, you can use the coordinates of the other three vertices to determine the coordinates of the fourth vertex.
