How to calculate the inertia of gearbox?
  • Automotive
  • Thread starter Sri_Vars
  • Tags
    Inertia
In summary, the Gearbox Inertia Procedure is as follows:1) Calculate the inertia of each rotating assembly.2) Calculate gear ratios.3) Define the starting point. It's normally the output shaft.4) The output shaft is geared to the input shaft with a gear ratio. The inertia of the input shaft reflected to the output shaft is the inertia of the input shaft multiplied by the square of the gear ratio between the two shafts.5) Proceed to the next shaft. The inertia of the next shaft reflected to the output shaft is the inertia of the next shaft multiplied by the square of the gear ratio between the output and next shafts. 6) The inertia
Sri_Vars
Do I have to sum the inertia of all the gears and shafts? If so, how to do that?
Welcome to PF.
That depends on what type of gearbox it is.
The traditional automotive gearbox uses an input shaft that drives the lay (or counter) shaft. The output shaft is, in effect, a single unit. The ratio of the input shaft to the output shaft is gear dependent.
The moment of inertia of three subsystems must be measured or calculated.
1. The engine and flywheel should include the clutch pressure plate.
2. The gearbox input shaft and lay shaft should be grouped with the clutch friction disc.
3. The gearbox output shaft should be grouped with the drive shaft, differential, drive axles and all wheels.
Thank you Mr. Baluncore for your answer.
We are currently using the traditional gearbox only. But I am not sure how to calculate the inertia of the subsystems. It would be so helpful if you could brief it with formula.
You will need to dismantle the gearbox, then weigh and measure every component. Take a look at a gearbox parts diagram to see how many items are held on the main shaft.
The pitch diameter of a gear will be misleading due to the radius squared. You will have to approximate gear wheels as polygons, or find some other way.
A ball bearing race will probably have the inner race moving, the outer race static, and the balls spinning, somewhere in between.
https://en.wikipedia.org/wiki/Second_moment_of_area#Examples
https://en.wikipedia.org/wiki/List_of_moments_of_inertia
Likes Sri_Vars
Thank you so much for your help!
No, because all gears and shafts don't necessarily have the same angular velocity. You can do a free body diagram for each rotating component which will give you a set of equations to solve (1 equation for 1 unknown).
This post shows how to do it with the equivalent kinetic energy method.
Yes. And you have to calculate the inertia of each component reflected to a common point in order to include the effects of gear ratios. Having done this calculation more than a few times, here's the procedure that I use. It's the same as the procedure in the post linked in Post #6 by @jack action above, just stated differently.
2) Calculate all gear ratios.
3) Define the starting point. It's normally the input shaft.
4) The input shaft is geared to the second shaft with a gear ratio. The inertia of the second shaft reflected to the input shaft is the inertia of the second shaft multiplied by the square of the gear ratio between the two shafts.
5) Proceed to the third shaft. The inertia of the third shaft reflected to the input shaft is the inertia of the third shaft multiplied by the square of the gear ratio between the input and third shafts.
6) The inertia of each shaft is the total inertia of the rotating components attached to that shaft.
7) When you have the inertia of all rotating components reflected to the input, then sum them. That's the inertia of the gearbox at the input shaft.
If you want the inertia at the output shaft, the procedure is similar, except that you start at the output shaft and work back to the input shaft.
FAQ: How to calculate the inertia of gearbox?
What is inertia and why is it important in a gearbox?
Inertia is the resistance of an object to changes in its state of motion. In a gearbox, the inertia is important because it affects the speed and efficiency of the gear system. A high inertia can result in slower acceleration and deceleration, while a low inertia can lead to faster and smoother movements.
How do you calculate the inertia of a gearbox?
The inertia of a gearbox can be calculated by multiplying the mass of each gear by the square of its radius and adding all the individual inertias together. This calculation can be simplified by using the moment of inertia equation, which takes into account the shape and distribution of mass in the gears.
What units are used to measure inertia?
Inertia is typically measured in units of kilogram-meter squared (kg-m^2) or pound-foot squared (lb-ft^2). These units represent the mass and distance from the axis of rotation, respectively.
How does the number of gears in a gearbox affect its inertia?
The number of gears in a gearbox does not directly affect its inertia. However, the size and distribution of the gears can impact the overall inertia of the system. In general, a gearbox with more gears may have a higher inertia due to the additional mass and contact points between gears.
Can the inertia of a gearbox be changed?
Yes, the inertia of a gearbox can be changed by altering the size, shape, or distribution of mass in the gears. This can be achieved by using different materials, adjusting gear ratios, or adding flywheels or other components to the system.
