How to calculate the number of photons
  • Thread starter Buzz Bloom
  • Tags
    Photons
In summary, an issue arose about photons and gas in equilibrium and the question was raised about how to calculate the number of photons in a container of gas at a certain temperature. After researching and working through a few equations, it was estimated that there are approximately 6 * 10^14 photons/m^3 in the container. This estimate was later corrected to be about 250 times smaller due to a factor error in the original formula. Additionally, it was noted that in an expanding universe, the average number of photons and the entropy of the photon gas does not change.
Buzz Bloom
467
An issue arose in another thread about photons and gas in equilibrium. I made an effort to find an answer searching the internet, but my researching skills are not up to the task. The following is one example of the question for which I would like to learn how to calculate the answer.
Given one mole of H2 gas in a spherical container of radius one meter with a perfect insulation boundary, and the gas is in equilibrium with photons at a temperature of 300 kelvin, how many photons (approximately) are in the container with the gas?
Science news on Phys.org
The Planck blackbody function, radiation per unit area per unit wavelength ## M(\lambda, T)=\frac{2 \pi hc^2}{(\lambda^5)(e^{\frac{hc}{\lambda k T}}-1)} =n(\lambda) \, (\frac{c}{4})( \frac{hc}{\lambda} ) ## where ## n(\lambda) ## is the photon density per unit volume per unit wavelength. To get the photon density per unit volume ## n =\int\limits_{0}^{+\infty} n(\lambda) \, d \lambda ## . This is the easiest way I know of computing it. ## \\ ## Basically I worked backwards from a step in the derivation of ## M(\lambda, T) ##, where the photon density per unit volume per unit wavelength ## n(\lambda) ## has already been computed, and the next (final) step in getting ## M(\lambda, T) ## is to use the effusion rate formula ## R=\frac{n \bar{v}}{4} ## with ## \bar{v}=c ##, and ## n ## is made to be ## n(\lambda) ## because we are working with a spectral density here. This gets multiplied by ## E_p=\frac{hc}{\lambda} ## to give ## M(\lambda, T)=n(\lambda) (\frac{c}{4})(\frac{hc}{\lambda}) ##. The ## M(\lambda, T) ## in the form above (first line) is a very well-known result. This is easier than repeating the steps of the Planck function derivation where ## n(\lambda) ## gets computed after about 9 or 10 steps. ## \\ ## For a rough estimate, we can use ## \int\limits_{0}^{+\infty} M(\lambda, T) \, d \lambda=\sigma T^4 ##,(which is exact), where ## \sigma=5.67 \cdot 10^{-8} ## watts/(m^2 K^4), along with Wien's law, ## \lambda_p T=2.898 \cdot 10^{-3} ## m K, and a good estimate for ## \bar{\lambda} \approx 2 \lambda_p ##. This would get us an estimate for ## n ## without doing the integral of ## n=\int\limits_{0}^{+\infty} n(\lambda) \, d \lambda \approx \frac{\big{(}\int\limits_{0}^{+\infty} M(\lambda,T) \, d \lambda \big{)}\,(4) (2 \lambda_p)}{hc^2}=\frac{(\sigma T^4)(4)(2)(\frac{2.898 \cdot 10^{-3}}{T})}{hc^2} ##. My arithmetic (which I need to check) gets that ## n \approx 6 \cdot 10^{14} ## photons/m^3 . ## \\ ## A numerical (speadsheet) integration of ## n=\int\limits_{0}^{+\infty} n(\lambda) \, d \lambda ## would be more accurate, but I expect it would get a similar result.
Likes Dale and Buzz Bloom
Charles Link said:
A numerical (speadsheet) integration of n=+∞∫0n(λ)dλ n=\int\limits_{0}^{+\infty} n(\lambda) \, d \lambda would be more accurate, but I expect it would get a similar result.
Hi Charles:
Thank you very much for your post. I plan to use an online tool
to do the numerical integration. It has been very helpful to me in the past.
Regards,
Buzz
Buzz Bloom said:
Hi Charles:
Regards,
Buzz
You are welcome. I'd be very much interested in seeing what you get for an answer. I anticipate my estimate is reasonably good.
@Buzz Bloom I decided to google it, and it appears the answer can be written in closed form. See the formula for ## N ## in the table, which is proportional to ## V ##: https://en.wikipedia.org/wiki/Photon_gas ## \\ ## Edit: This result is giving me an answer about a factor of 250 smaller than what I computed above. I wonder if perhaps their ## h ## should be a ## \hbar=\frac{h}{2 \pi} ##.## \\ ## Additional edit: Comparing with what Reif has on p.375 of Statistical and Thermal Physics, it appears that indeed should be a ## \hbar ## in their formula. Yes, also see their footnote: Others have already pointed out this same error. (Just above the table in the fine print: see the words "disputed" in blue). It appears with the added factor of ## (2 \pi)^3 ## , they are now in agreement with my estimate above.
Likes Buzz Bloom
Hi @Charles Link:
Thanks again very much for your help. When I tried to search the Internet for the information, I did not know to use the phrase photon gas. The formula for N is actually quite helpful since it makes clear that in an expanding universe the average number of photons does not change. The formula for S also makes clear that the entropy of the photon gas does not change. These points are relevant to the discussion on the thread
Regards,
Buzz
Likes Charles Link
Related to How to calculate the number of photons
1. How do you calculate the number of photons in a given area?
In order to calculate the number of photons in a given area, you will need to know the energy of each individual photon and the total energy in the given area. The equation for this is: Number of photons = Total energy / Energy of each photon.
2. What is the energy of a single photon?
The energy of a single photon is determined by its frequency or wavelength. The equation for this is: Energy of a photon = Planck's constant x frequency or Energy of a photon = Planck's constant x speed of light / wavelength.
3. Can you calculate the number of photons in a vacuum?
Yes, you can calculate the number of photons in a vacuum. The energy of a single photon is still determined by its frequency or wavelength, and the total energy in the vacuum can be measured or estimated. The same equation applies: Number of photons = Total energy / Energy of each photon.
4. How does temperature affect the number of photons in a given area?
Temperature can affect the number of photons in a given area because it can affect the energy of each individual photon. As temperature increases, the energy of each photon also increases. This means that there will be more photons in a given area at higher temperatures compared to lower temperatures.
5. Can you calculate the number of photons in a material object?
Yes, you can calculate the number of photons in a material object. However, this calculation may be more complicated as the material object may have varying levels of transparency or opacity, which will affect the total energy and the energy of each individual photon. The same equation applies, but it may require more precise measurements and calculations.
  • Quantum Interpretations and Foundations
  • General Engineering
