How to Calculate the Sum of Squares in Complex Equation Systems?
  • MHB
  • Thread starter anemone
In summary, to solve for x, y, z, and w in this system of equations, you will need to use algebraic manipulation and elimination techniques to isolate each variable. You can also use substitution, graphing, or technology to assist with the solution process. Additionally, finding x^2+y^2+z^2+w^2 can simplify the equations and make it easier to solve. To check your solution, plug the values back into the original equations and ensure that they all result in true statements.
anemone
MHB
POTW Director
3,883
115
Here is this week's POTW:
Determine $x^2+y^2+z^2+w^2$ if
$\dfrac{x^2}{2^2-1^2}+\dfrac{y^2}{2^2-3^2}+\dfrac{z^2}{2^2-5^2}+\dfrac{w^2}{2^2-7^2}=1,\\\dfrac{x^2}{4^2-1^2}+\dfrac{y^2}{4^2-3^2}+\dfrac{z^2}{4^2-5^2}+\dfrac{w^2}{4^2-7^2}=1,\\\dfrac{x^2}{6^2-1^2}+\dfrac{y^2}{6^2-3^2}+\dfrac{z^2}{6^2-5^2}+\dfrac{w^2}{6^2-7^2}=1,\\\dfrac{x^2}{8^2-1^2}+\dfrac{y^2}{8^2-3^2}+\dfrac{z^2}{8^2-5^2}+\dfrac{w^2}{8^2-7^2}=1$
No one answered last week's problem.(Sadface)
You can find the suggested solution below:
The claim that the given system of equations is satisfied by $x^2,\,y^2,\,z^2$ and $w^2$ is equivalent to claiming that
\(\displaystyle \dfrac{x^2}{t-1^2}+\dfrac{y^2}{t-3^2}+\dfrac{z^2}{t-5^2}+\dfrac{w^2}{t-7^2}=1 \tag{1}\)
is satisfied by $t=4,\, 16,\,36$ and $64$.
Clearing the fractions, we find that for all values of $t$ for which it is defined (i.e. $t\ne 1,\,9,\,25$ and $49$), $(1)$ is equivalent to the polynomial equation $P(t)=0$, where
$P(t)=(t-1)(t-9)(t-25)(t-49)-x^2(t-9)(t-25)(t-49)-y^2(t-1)(t-25)(t-49)\\
\,\,\,\,\,\,\,\,\,\,\,\,\,\,\,\,\,\,\,-z^2(t-1)(t-9)(t-49)-w^2(t-1)(t-9)(t-25)$
Since degree $P(t)=4,\,P(t)=0$ has exactly four zeros $t=4,\,16,\,36$ and $64$, i.e.,
$P(t)=(t-4)(t-16)(t-36)(t-64)$
Comparing the coefficients of $t^3$ in the two expressions of $P(t)$ yields
$1+9+25+49+x^2+y^2+z^2+w^2=4+16+36+64$,
from which it follows that
$x^2+y^2+z^2+w^2=36$
FAQ: How to Calculate the Sum of Squares in Complex Equation Systems?
What is the purpose of finding the sum of squares using a system of equations?
The purpose of finding the sum of squares using a system of equations is to solve for the values of the variables x, y, z, and w that satisfy the system of equations and also make the sum of their squares equal to a given value. This can be useful in various mathematical and scientific applications.
How do you set up a system of equations to find the sum of squares?
To set up a system of equations to find the sum of squares, you need to first identify the variables involved in the sum of squares (in this case, x, y, z, and w). Then, you can write equations that relate these variables and also include the given sum of squares value. For example, you could write the equations x + y + z + w = 10 and x^2 + y^2 + z^2 + w^2 = 50 to find the values of x, y, z, and w that satisfy these equations and make the sum of their squares equal to 50.
What are the steps to solve a system of equations to find the sum of squares?
The steps to solve a system of equations to find the sum of squares are as follows:
  1. Identify the variables involved in the sum of squares.
  2. Write equations that relate these variables and include the given sum of squares value.
  3. Solve the system of equations using algebraic methods such as substitution or elimination.
  4. Check your solution by plugging the values of the variables into the original equations and making sure they satisfy the given sum of squares value.
Are there any special cases or exceptions when solving a system of equations to find the sum of squares?
Yes, there are a few special cases or exceptions to keep in mind when solving a system of equations to find the sum of squares:
  • If the given sum of squares value is negative, there will be no real solutions to the system of equations.
  • If the given sum of squares value is 0, there will be infinitely many solutions to the system of equations.
  • If the given sum of squares value is positive and all the variables have the same coefficient, the solutions will be symmetric (i.e. the values of the variables will be equal).
What are some real-world applications of finding the sum of squares using a system of equations?
Finding the sum of squares using a system of equations has various real-world applications, including:
  • In statistics, the sum of squares is used to measure the variability of a set of data.
  • In physics, the sum of squares is used to calculate the total energy of a system.
  • In engineering, the sum of squares is used to optimize designs and minimize errors.
  • In finance, the sum of squares is used to measure risk and volatility in investment portfolios.
