How to calculate the wavelength of light coming from 1 light year away
In summary, calculating the wavelength of light from a source 1 light year away requires understanding the concept of light and its various frequencies. The Hubble expansion formula is not applicable at this scale as stars within a galaxy are gravitationally bound and not receding from us. The relative motion of the star in its path around the galaxy is the only source of a Doppler shift.
shantanu23
TL;DR Summary
How to calculate the wavelength of light coming from 1 light year away.
Is there any formula for it.
Please help.
Astronomy news on Phys.org
shantanu23 said:
Summary:: How to calculate the wavelength of light coming from 1 light year away.
Please help.
I think you have a fundamental misunderstanding of light. "Light" is an English language term which is used either for (1) any frequency of electromagnetic radiation or for (2) that range of the electromagnetic spectrum which is in the visible by humans.
The wavelengths range from near zero to extremely high. If there is no proper motion between you and the 1 light year distant object, then the wavelength is just a measure of what in English is called the "color". If there IS proper motion then there can be red or blue shifting so that the wavelength you see is not exactly that emitted.
Are you talking about the Expansion of the Universe and the red shift here? A quick buzz through this wiki link will tell you what you need to know and the context.
The equation v = H0D tells you only the average speed of recession v for galaxies at distance D, due to the actual expansion of the space. That is only a ballpark figure because there will be motion of Earth relative to each galaxy.
If you measure the frequency of a spectral line in light from a galaxy, you can use the Doppler Formula to obtain v from the frequency shift relative to the spectrum of the elements on Earth.
The Hubble expansion formula doesn't apply to nearby stars - in our own galaxy - because they are constrained by the local gravitational field within the galaxy. H0 can only be used for galaxies because they are considered 'independent' of the mass of our galaxy. But you can tell the relative motion between a star and Earth by measuring the frequency shift (red or blue, depending)
It's down to what you actually describe as a galaxy (see this link and others) but the sort of distance between us and the nearest dense groups of stars is tens of thousands of light years and small galaxies in our local cluster are much further away than that. Hubble definitely can't tell you anything about the likely frequency shift at 1LY.
More than that, there is no effect from the expansion of the universe at this scale. Stars in a galaxy (or even the local group of galaxies) are gravitationally bound and are not receding due from us as more distant objects are. The relative motion of the star in its path around the galaxy is the only source of a Doppler shift.
Likes sophiecentaur
Which is why I responded the way I did, given that he was talking about only a 1 LY distance.
Likes sophiecentaur
Related to How to calculate the wavelength of light coming from 1 light year away
1. What is the formula for calculating the wavelength of light from 1 light year away?
The formula for calculating the wavelength of light is: wavelength = speed of light / frequency. In this case, the speed of light is a constant value of 299,792,458 meters per second and the frequency is the number of waves per second.
2. How do I determine the frequency of light coming from 1 light year away?
The frequency of light can be determined by dividing the speed of light by the wavelength. In this case, the wavelength is the distance between two consecutive peaks or troughs of the light wave.
3. Can I use the same formula to calculate the wavelength of all types of light?
Yes, the formula for calculating the wavelength of light is the same for all types of light, including visible light, infrared, ultraviolet, and others. The only difference may be the frequency of the light, which can vary depending on the type of light.
4. Is there a specific unit of measurement for the wavelength of light?
The wavelength of light is typically measured in meters, but it can also be measured in other units such as nanometers, micrometers, or angstroms. The unit used will depend on the size of the wavelength being measured.
5. How accurate is the calculation of the wavelength of light from 1 light year away?
The calculation of the wavelength of light from 1 light year away is very accurate, as long as the speed of light and frequency are known with precision. However, due to the vast distances involved, there may be some margin of error in the measurement of these values.
  • Astronomy and Astrophysics
10K
