How to calculate this integral?
  • Thread starter Thread starter neptunecs
    Integral
neptunecs
Hi,How to calculate this integral:
which
I have ever calculated it and the result(R(s)) is ∞,but I don't think it's right,I'm not sure with it.
Thank you for your help!
neptunecs.
which
neptunecs.
It'll take forever for the attachments to be approved, why not just use LaTex?
where is LaTex in this forum?I didn't find it.Tell me,please.Thanks.
R(s)=\int_{-\infty}^{\infty} f(t)f(t+s) dt
which f(t)=Acos(wt+f0)
Thank for Curious3141's help!
neptunecs.
\int\cos mx \cos nx dx=\frac{\sin(m-n)x}{2(m-n)}+\frac{\sin(m+n)x}{2(m+n)}+c
Of course the c will go because you have limits.
(This integral can be found in the front or back of most Calculus textbooks.)
Thank you for Curious3141's help!
neptunecs.
You're welcome. If you're not that interested in the method, a quick way to get an answer is to try this link : http://integrals.wolfram.com/index.jsp
Just input the integrand as "b Cos[w x+k]b Cos[w(x+l)+k]" since the script uses x as the integrand by default. The constant I changed from A to b because Acos has a special meaning of arccosine. f0 corresponds to k and s corresponds to l.
EDIT : I had previously made a small error in the expression which changes the indef. integral but does not affect the convergence of the integral for the given bounds. Now the integrand expression is correct.
And you're right, for the bounds given, the integral does not converge.
Or he could've converted the integrand to complex form.. :D
Thank you.
But the integral does not converge seems strange.Maybe my teacher made a mistake.
I made a mistake in giving you that standard solution due to the phase shifts in your integrands...
Using the mathematica link, the solution should be:
\frac{A^2}{2}\left[t\cos(\omega s)+\frac{\cos(2\omega t)\sin(2f_0+\omega s)}{2\omega}+\frac{\cos(2f_0+\omega s)\sin(2\omega t)}{2\omega}\right]^\infty_{-\infty}
Though you should check it too... the non-convergence thing still stands...
Thank very much.This solution is particular.
my teacher said It's non-convergence thing, too.
neptunecs.
