How to calculate time of Pressurization in vessel?
  • Thread starter METCON
In summary, calculating the time of pressurization in a vessel involves determining the required pressure, the vessel's volume, and the flow rate of the gas being introduced. The formula used is based on the ideal gas law and the specific characteristics of the system. Key steps include measuring the initial conditions, applying the flow rate to find the time needed to reach the desired pressure, and considering any losses or inefficiencies in the system. Proper safety measures should also be taken into account during the process.
METCON
TL;DR Summary
"Urgent: Need Expert Advice on Calculating Pressure Buildup in Fixed Volume Vessel!"
Hello community,
I'm currently facing a challenging situation and would greatly appreciate some expert advice. Here's the scenario:
I have a fixed volume vessel with a total volume of 15458 ft³. The volumetric flow rate through this volume is 90 MMSCFD. The initial temperature of the gas is 80°F, with a Compressibility Factor of approximately 0.91 and a Molecular Weight of 22.9. The source pressure is 300 PSIG, and the normal operating pressure is 100 PSIG.
My concern is understanding the time it would take for the pressure to reach 250 PSIG if the exit of the vessel were to be suddenly shut. Assume no heat transfer and no additional information on piping dimensions.
I'm reaching out to this knowledgeable community for assistance in calculating this pressure buildup time. Any insights, formulas, or guidance on how to approach this problem would be immensely helpful.
Your expertise is highly valued, and I'm eager to hear your thoughts on this matter. Thank you in advance for your time and assistance!"
Feel free to make any adjustments or let me know if you have specific preferences!
Thanks!
-METCON
This flowrate unit, MMSCFD = One million standard cubic feet per day, is typically used in the natural gas industry. Are there significant safety concerns (rupture, flammability or detonation) impacted by this calculation?
Likes berkeman
@renormalize no there are no concerns with this. the system is protected by redundant safety systems to mitigate this risk.
Are you willing to make the approximation that the gas behaves as an ideal gas?
Not 'expert' advice:
In round numbers / Ideal gas: approx 2.5 minutes. More precision will not produce more accuracy without a lot more detail (actual supply flow vs pressure, thermal...).
Ideal gas is ok. The entire basis is approximated.
Meaning, to mitigate the risk of the exit valve being shut?
If so, what is the point of the calculation you are asking about?
Generally speaking, engineering risk calculations are not something that should be done here at PF. They should be done by experts on the spot who are responsible to whoever owns the system.
Likes berkeman
Can you please detail those redundant safety systems for us? Thank you.
@berkeman @PeterDonis Lets assume the theoretical system has an MAWP of 500 PSIG, is and is equipped with a relief device.
I'm looking for a general approach to find the time it takes for the system to go from operating pressure to target pressure while being fed by a source pressure and flowrate. I have approached this from the work equation by integrating for change in pressure. w= ∫ VdP = P1*V1*ln( P2/P1 ). Finding the work to fill the volume from 100PSIG to 250PSIG, then finding the work done by compression , inlet flowrate 90MMSCFD and source pressure 300PSIG. Then dividing the work to fill the volume by the work done by compression to find the time. Flowrate provides the time unit. Is this the correct approach? Maybe more importantly, is my integration correct? It has been a while...
I tried to take an PV=nRT approach to this with the molar flow rate of the gas but I can't seem to make it work...
@Dullard can you explain how you got to 2.5min?
Thank you all.
So basically you're filling the tank and you want to estimate how long it will take?
Thank you all.
Are you measuring the source pressure and the flowrate, or just the source pressure?
Source pressure and flowrate is known. 300 PSIG, 90MMSCFD.
"@Dullard can you explain how you got to 2.5min?"
I can:
Think in 'Bar-Ft3'
Your initial and final conditions are specified in your post. The 'tank content' change is the tank volume (fixed) multiplied by the pressure change (10 Bar). The supply flow rate is in Ft3/min. content change / flow rate = time.
This doesn't account for non-idealities or thermal effects, but it's a decent approximation.
Likes METCON
You can also go this route(I think), which would be a bit more detailed, but also probably not nearly detailed enough...
let ##m## be the mass of the gas in the tank.
$$ \frac{dm}{dt}= \rho_s Q \tag{1} $$
where the RHS is a constant by your approximation
Using the Ideal Gas Law to find ##m## ( not likely valid due to the dynamics)
$$ P = \frac{R_{air}}{V}mT \tag{2}$$
##P## is the instantaneous tank pressure
##V## tank volume
##R_{air}## specific ideal gas constant
##T## instantaneous tank gas temperature
sub (2) Into (1) for ##m##
$$ \frac{V}{R_{air}}\frac{d}{dt}\left( \frac{P}{T} \right)= \rho_s Q \tag{3} $$
Then with an adiabatic expansion we have:
$$ T = T_s \left( \frac{P}{P_s} \right)^{(k-1)/k} \tag{4} $$
##T_s## is the temp of the source gas
##P_s## is the source pressure
##k## is the ratio of specific heats
sub (4) into (3) for ##T##
$$ \frac{V}{R_{air}}\frac{d}{dt}\left( \frac{P}{T_s \left( \frac{P}{P_s} \right)^{(k-1)/k}} \right)= \rho_s Q \tag{5} $$
Then you can simplify and solve (5) for ##P(t)## by separation of variables with initial condition ##P(0) = P_o##
Take care to use absolute temp, pressures, etc... and your volumetric flowrate is a standardized cfm, I believe you should be careful with how that factors into the RHS value for mass flowrate.
When I solve the equation above, I get about ##1.95 ~\rm{min} ## for air. That agrees very well with @Dullard 's approximation. However, it is an unrealistic representation as the tank pressure will not approach line pressure asymptotically with this constant mass flowrate assumption - it shoots right past and keeps going. I think the best we can say with this simplistic model is this is a minimum possible time to reach ##254.7 ~\rm{psia} ##.
Assume that the gas is ideal, and let the subscript 0 represent the initial steady state parameters for the tank and the subscript 1 represent the parameters when the pressure in the tank reaches ##P_1##. Let ##m_0## represent the steady sate moles of gas in the tank and ##\delta m=m_1-m_0##. Then the ideal gas law gives: $$P_0V=m_0RT_0$$ and $$P_1V=(m_0+\delta m)RT_1$$
Assume that the gas being fed to the tank is at the same temperature as the steady state temperature ##T_0##. Taking as our closed adiabatic system the initial steady state moles in the tank ##m_0## plus the number of moles ##\delta m## injected until the tank pressure is ##P_1##, we have $$(m_0+\delta m)C_v(T-T_0)=P_{ext}\delta v=P_{ext}\frac{\delta m RT_0}{P_{ext}}=\delta m RT_0$$where ##\delta v## is the volume injected at 300 psi. Solving this for the final temperature gives: $$\frac{T_1}{T_0}=1+(\gamma-1)\frac{\delta m}{m_0+\delta m}$$. The temperature ratio can be eliminated from the above 3 equations to give ##\frac{\delta m}{m_0}## as a function of ##P_1/P_0##.
Likes Dullard
FAQ: How to calculate time of Pressurization in vessel?
How do you determine the initial and final pressures for pressurization calculations?
To determine the initial and final pressures for pressurization calculations, you need to know the starting pressure (P1) inside the vessel and the target pressure (P2) you aim to achieve. These values are typically given in units of pressure such as Pascals (Pa), atmospheres (atm), or pounds per square inch (psi). You can measure the initial pressure using a pressure gauge and set the final pressure based on the requirements of your process or system.
What is the formula for calculating the time of pressurization in a vessel?
The formula for calculating the time (t) of pressurization in a vessel depends on several factors, including the volume of the vessel (V), the flow rate of the pressurizing gas (Q), and the initial and final pressures (P1 and P2). One common approach is using the ideal gas law and integrating it over time. For a constant flow rate, the simplified formula is often given as:\[ t = \frac{V}{Q} \ln\left(\frac{P2}{P1}\right) \]where:- \( t \) is the time of pressurization,- \( V \) is the volume of the vessel,- \( Q \) is the flow rate of the gas,- \( P1 \) is the initial pressure,- \( P2 \) is the final pressure.
How does the flow rate of the gas affect the pressurization time?
The flow rate of the gas (Q) is directly proportional to the pressurization time. A higher flow rate means that the gas is being introduced into the vessel more quickly, thus reducing the time required to reach the desired pressure. Conversely, a lower flow rate will increase the pressurization time. It's important to ensure that the flow rate is consistent and accurately measured to calculate the pressurization time correctly.
What role does the volume of the vessel play in pressurization calculations?
The volume of the vessel (V) is a critical factor in pressurization calculations. A larger vessel volume requires more gas to achieve the same pressure increase compared to a smaller vessel. Therefore, the pressurization time will be longer for larger vessels if all other factors (such as flow rate and pressure difference) remain constant. Accurate measurement of the vessel volume is essential for precise calculations.
Are there any assumptions or limitations in the pressurization time calculations?
Yes, there are several assumptions and limitations in pressurization time calculations. One common assumption is that the gas behaves ideally, following the ideal gas law. This may not be accurate for gases at very high pressures
9K
